Old 8/26/08, 5:25 PM
Mick D. Jones Mick D. Jones is offline
Please Note: Mick D. Jones is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Power Supply to Subpanel
I have a sub panel that is powered by wires tapped directly into the main lugs of the main panel. My inspector pointed this out but an electrician is saying it's ok. Does anyone have a code saying one way or the other. I found your site and it seems like there are some electricians on here.
Old 8/26/08, 5:42 PM
Marc D. Shunk's Avatar
Banned
Default Re: Power Supply to Subpanel
Please post your pictures.
What was the distance from that bus tap to the breaker it terminated on in the subpanel? This can be legal, but there are distance and a few other limitations.
The typical violation of what you describe would be if those lugs were double tapped, which I might guess they were. Darned few lugs are rated for more than one large conductor in the sizes we're likely dealing with in this scenario.
Old 8/26/08, 5:43 PM
Jeffrey R. Pope's Avatar
Yes, there are codes that address the issue(s). One with regards to the listing of the lugs - whether they're rated for more than one conductor, and another referencing the requirement for a disconnect, and yet another for appropriate over-current protection for the conductors supplying the panel.
Do you have a picture?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/26/08, 5:51 PM
I don't have a picture right now. I'm not home to take a picture it is a push matic box? The house was built in the late 50's early 60's. The aluminum wires come in to the main lugs and there is braided copper wires attached there.
Old 8/26/08, 10:30 PM
Brian E. Kelly's Avatar
You mean the Electrician did not know what part of the code he was referring too that allowed this condition?
Old 8/27/08, 12:17 AM
Terry Clayton Terry Clayton is offline
if I understand you correctly they tapped the main lugs before the main disconnect if so they cannot disconnect the sub panel with the main breaker in the main panel and this would be a violation. The Pushmatic lugs would not be rated for a double tap the buss would have to be tapped and lugs installed or a breaker installed in the body of the panel used to disconnect the sub panel.
Old 8/27/08, 5:55 PM
Banned
Actually, you couldn't be more wrong. This can be legal under certain conditions. The double tap, if one exists, is the real violation.
Power to subpanel lfoster Electrical Inspections 2 4/3/08 2:11 PM
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 72 3/12/08 12:19 AM
Selected Electrical Incidents and Occurrences - First Quarter pabernathy Electrical Inspections 0 12/2/07 2:43 PM
supply in slab or walls? jeubank Plumbing Inspections 1 7/8/06 11:36 AM
Emergency Lighting (commercial) mcyr Electrical Inspections 24 6/10/06 11:06 AM
