Every once in a while you see one that is just so pretty. Enjoy!
Yup...New Construction, I bet.
I would have to report "No room for expansion" 42 slots - all filled up.
tg |
That's the rest of my report on this panel!! You been reading my reports?
tg |
That is a clean job and remarking the white wires at the double pole breakers is recommended.
Saw one just this very day!! It didn't have as many breakers though.
But it is a pleasure to open the panel and see that... "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
Greg Gillis is a non-member guest and is in no way affiliated with InterNACHI or its members.
Are the AFCI breakers supposed to be seperated? I thought they build up heat from their mini computers and should not be stacked together.
Saw these yesterday. Also new construction. 2 - 200 amp panels and 2 100 amp subs.
http://www.SmithHomeInspection.com SmithHomeInspection@yahoo.com NY State Lic. # 16000008304 631-434-5200 |
Greg,
Nope....the ARC FAULTS are fine stacked together. Paul W. Abernathy |
Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
If I am seeing this picture correctly, then:
I hate to be a killjoy here, but there are some violations, and as an electrical inspector, I would have this panel rewired. 312.5(C) exception conductors enter the panel through a raceway so, 1. the panel is required to be surface installed. 2. pipe fill 3. ampacity adjustment 4. the raceway is not permitted to penetrate a finished ceiling. 5. the end of the raceway is required to be sealed or plugged. 6. the cables are all required to be fastened within 12 inches of exiting the raceway. It is not possible to tell from the picture, but if the raceways are terminated into boxes (they would have to be large enough for conductor fill), then this installation is a good one. |
Isn't mounting on plywood a no-no? Thought it had to be a 'non-combustible' surface.
Or is that just us yokels in Chicago? Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
