Old 10/9/09, 7:40 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Is this a problem???
The local sparky and the local AHJ says these double taps are not a problem.
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Find an InterNACHI certified California Home Inspector (and anywhere else in North America)
Old 10/9/09, 7:48 PM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: Is this a problem???
Sounds like at least two more people need a Code update class or read the label inside the panel.
Old 10/9/09, 8:19 PM
James F. McKee's Avatar
so they are kidding ...right?
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 10/9/09, 8:21 PM
Christopher Currins's Avatar
ARTICLE 408 Switchboards and Panelboards
408.41 Grounded Conductor Terminations.
Each grounded conductor shall terminate within the panelboard in an individual terminal that is not also used for another conductor.
Exception: Grounded conductors of circuits with parallel conductors shall be permitted to terminate in a single terminal if the terminal is identified for connection of more than one conductor.
Christopher Currins
Certified, Licensed
Old 10/9/09, 8:23 PM
kluce kluce is offline
Please Note: kluce is a non-member guest and is in no way affiliated with InterNACHI or its members.
It hard to say what you are talking about since everything looks good.
If you are talking about the neutral and ground wires, it's fine.
Old 10/9/09, 8:24 PM
Jeffrey R. Pope's Avatar
In what part of the world would that be? Even the panel listing will tell you this is wrong. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/9/09, 8:42 PM
Two hot wires are not allowed.
Two neutral wires not allowed.
But a neutral and a ground from the same circuit, why not?
Old 10/9/09, 8:47 PM
It's specifically prohibited in the NEC, and is in direct contradiction with the listing of the panel.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 10/9/09, 8:50 PM
Still don't know what is the worst thing that can happen.
Around here it is considered an acceptable practice. I don't know one city inspector that will call it out.
I'm so use to seeing this type of installation around here that I never questioned it. I though I seen in the NEC that a neutral and ground are allowed. I'll have to look.
Old 10/9/09, 8:55 PM
mnahrgang's Avatar
Acceptable practice???? Um....do the letters "BS" mean anything to you?
Mark Nahrgang
www.HeyMark.info
Old 10/9/09, 9:01 PM
The picture in question are not two neutrals. They are a neutral and a ground wire.
I agree that two neutrals are not allowed and clearly noted in the NEC. City Inspectors around here would also not allow that kind of installation.
Old 10/9/09, 9:07 PM
The NEC says nothing about two neutrals;
408.21 Grounded Conductor Terminations. Each grounded conductor shall terminate within the panelboard in an individual terminal that is not also used for another conductor.
The panel listing allows for 1 neutral per termination, and up to 3 grounding conductors per termination.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 10/9/09, 9:26 PM
Trying to get a home inspection report done so I don't have time now to look it up.
Still don't know what the worst thing that can happen.
Old 10/9/09, 9:30 PM
Patrick Bolliger's Avatar
In general terms:
I believe it has to do with the "clamping pressure" of the terminal screw with respect to surfaces and a "current" carrying conductor. Normally the Grounding conductor is NOT carrying current (in a perfect world ,its a "safety") so they can be grouped per NEC up to three per termination as Jeff P. has posted.
If you add two "conductors" such as the Grounded (neutral, current carrying) conductor and a Grounding conductor under one terminal it maybe possibly to not properly "fastened" or properly apply correct pressure on the conductors for proper amperage (current) to pass on a smaller surface area due to clamping screw making less contact on the two conductors. Proper torque or pressure on the conductor also determines the amperage at that point. Think surface area and current with respect to responsibility of the conductor.
Old 10/9/09, 9:34 PM
Doug Edwards's Avatar
Here, read this. It will "esplain" it.
http://static.schneider-electric.us/...0100DB0705.pdf
- John Stuart Mill
Weird water heater problem kweiss Plumbing Inspections 3 4/5/09 6:34 PM
furnace problem ? Aaron lore General Inspection Discussion 11 2/5/09 1:04 PM
Internet browser problem bking Miscellaneous Discussion for Inspectors 33 1/26/09 1:45 AM
I have a problem cbottger Electrical Inspections 17 1/20/09 4:45 PM
Plumbing problem at home. mnahrgang Plumbing Inspections 25 7/10/07 5:32 PM
