Old 2/13/06, 9:22 PM
jweinberg's Avatar
jweinberg jweinberg is offline
Please Note: jweinberg is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Proper?
Old Fuse box taken out of metal box....new Square D Main Panel installed beside it.
Have used the abandoned old fuse box to make multiple (11) connections between new, short copper distribution wiring to the existing old Knob and Tube. These connections are made inside the old Fuse Box with a swing door.
Are wire nuts and the metal fuse box with an accesible door sufficient? Or should these connections be done inside a closed, inaccesible junction box?
Thanks....
Jeff
Old 2/13/06, 10:05 PM
Jeffrey R. Pope's Avatar
Default Re: Proper?
Splices/wire-nuts are okay in the j-box with a door.
Pretty common setup for a service upgrade.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 2/13/06, 10:08 PM
Default Re: Proper?
We do it all the time, but the inspector requests we drill and tap to screw the door shut with machine screws NOT pointed sheet metal screws which are forbidden on any enclosure. I also write "No fuses or breakers inside" altho I don't think that is a requirement. the box MUST be bonded whether it be by pipe or grounding wire. Also, the bonding must be through machine threaded screws. Self tapping screws and mounting screws are not allowed for bonding.
Old 2/13/06, 10:15 PM
Default Re: Proper?
Do they lock all the meters in San Jose like that? Or just when there is a history of non payment?
Old 2/13/06, 10:55 PM
jweinberg's Avatar
Default Re: Proper?
Thanks Jeff...
Old 2/13/06, 11:21 PM
Default Re: Proper?
I don't think I've ever seen a meter without a lock.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 2/14/06, 12:44 AM
jweinberg's Avatar
Default Re: Proper?
Me too. You just can't trust us Californians......
Old 2/14/06, 2:49 AM
Russel Ray's Avatar
Default Re: Proper?
The utility company uses similar locks here and in Texas where I grew up.
Old 2/15/06, 1:05 PM
ewbarker ewbarker is offline
Please Note: ewbarker is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Proper?
No comment on Knob & tube?
Old 2/15/06, 1:21 PM
Russel Ray's Avatar
Default Re: Proper?
Here's an article from About Homes:
INF-0060 from Electricity
PVC waste lines lagudo Plumbing Inspections 10 3/6/11 1:57 AM
Electricians Check List pabernathy Electrical Inspections 74 12/5/07 6:39 PM
What is the proper name of this "monster"? yolhovsky Ancillary Inspection Services & Additional Topics 34 11/15/07 1:35 PM
Proper Complaint Procedures rcooke Canadian Inspectors 0 8/15/06 10:35 AM
Are these proper connections? jweinberg Plumbing Inspections 9 5/25/06 8:32 PM
