Old 4/8/11, 4:24 PM
jcatania jcatania is offline
Default Proper Amps to Main
Can someone help me out. On an inspection I did yesterday the Main service disconnect by the meter had a 100amp breaker. Then on the sub panel in garage the main disconnect had a 200amp breaker. What should I have listed the service amps as 100 or 200. Thanks for anyone's help
Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/8/11, 4:25 PM
Roy D. Cooke, Sr's Avatar
Default Re: Proper Amps to Main
The weakest link in the system 100 amp breaker = a 100 amp service
Old 4/8/11, 4:56 PM
Robert Ernst Robert Ernst is offline
It's 100 amp. They more than likely just used a bigger panel for the subpanel than needed for some reason. There should have been a breaker in the main that feeded that sub panel and that breaker size would be what the subpanel can handle as long as the wire size is correct.
Old 4/8/11, 5:17 PM
Robert Meier's Avatar
So there is a 100 amp main disconnect at the meter and a panel in the garage fed from the 100 amp main disconnect?
Old 4/8/11, 7:25 PM
Thanks guys I did put 100amp service on the report.
Old 4/8/11, 7:26 PM
Yes as far as I could tell
Old 4/8/11, 9:01 PM
Then your setup is fine. The 200 amp main CB in the panel could be omitted (MLO panel) unless the garage is a detached structure.
Shut off valves required? jcahill Plumbing Inspections 11 9/2/08 1:07 AM
Electricians Check List pabernathy Electrical Inspections 74 12/5/07 6:39 PM
HVAC Proper AMPS lking Inspecting HVAC Systems 2 11/25/07 8:53 PM
