Old 10/25/07, 1:34 PM
David C. Macy's Avatar
Default Proper ground for Csst
Home is a 2007 build.
The main gas line is grounded to the service grounding electrode.
The home has CSST and the builder had it grounded to the gas line.
This is incorrect & a possible safety issue?
Is the correct installation of grounding the CSST is the the earth ground?
(Damm landscapers keep tearing up the cable)
Thanks for your responses.
ID:	15521   proper-ground-corrugated-stainless-steel-tubing-107507-034-small-.jpg.jpg
Old 10/25/07, 1:42 PM
Default Re: Proper ground for Csst
Looks okay from my house.
Now that I think about it more, it seems bonding near the black pipe gas line entry is what I read but here are a couple of links.
http://www.pddocs.com/csst/faq.aspx
http://www.nachi.org/forum/showthrea...sst+bonding%22
Larry Kage, CMI
231 929 3525
Old 10/25/07, 1:56 PM
Jeffrey R. Pope's Avatar
The gas line is bonded to the grounding electrode and the CSST is bonded to the rigid gas line. Bonding and grounding are different.
CSST manufacturers have specific bonding requirements which, in some cases, include installation of additional grounding electrodes. The requirements vary depending on the Lightning Density Zone (LDZ) of your area.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/2/07, 10:46 PM
Pierre Belarge Pierre Belarge is offline
Please Note: Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
Just a note of caution...especially for HIs.
I am in the process of doing research for this topic. Just to let you know that CSST is not UL listed, it is CSA listed. CSST was originally trying to get a UL listing and they did not pass the evaluation there.
The change in the manufacturers installation instructions which happened just recently has some discrepcencies.
1. did they go back to the listing company to get the new instructions evaluated by the listing company....
2. There are discrepcencies with the method they provide for bonding the system.
3. most problems they have encountered are due to lightning/grounding issues not bonding issues. This system is not permitted to be grounded
I could go on, but I will wait until I have received more info back.
As a HI, I would defer all discussions or recommendations back to the building department or AHJ and pass on that responsibility/liability.
Old 11/2/07, 10:52 PM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Thanks Pierre....
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 11/3/07, 6:56 AM
Joseph Hagarty,  CMI's Avatar
http://www.gastite.com/include/langu.../TB2007_01.pdf
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 11/3/07, 7:07 AM
Originally Posted by jhagarty
I have a similar one around here somewhere for Pro-Flex CSST...but off to an inspection shortly.
Larry Kage, CMI
231 929 3525
Electricians Check List pabernathy Electrical Inspections 74 12/5/07 6:39 PM
Unable to confirm proper ground.. gmathias Electrical Inspections 22 10/27/06 8:20 PM
Electrical Inspection Training for Home Inspectors jtedesco1 Inspection Education & Training 6 4/27/06 10:43 PM
Harmonized Ground Fault Circuit Interrupters jtedesco1 Electrical Inspections 5 3/21/06 8:48 AM
