Old 3/2/11, 11:12 AM
Richard W. Washington's Avatar
Richard W. Washington Richard W. Washington is offline
Default protective ring
The plastic ring that protects the wires when they pass through the panel board wall. What is it's name?
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/2/11, 11:13 AM
Brian E. Kelly's Avatar
Default Re: protective ring
Grommet
Old 3/2/11, 11:14 AM
Jeffrey R. Pope's Avatar
Bushing...
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/2/11, 12:11 PM
Jim Port Jim Port is offline
Unmoderated Guest
While a bushing or a grommet would prevent chafing damage to the cable they are not securing the cable to the enclosure as required. There should be a cable clamp installed to hold the cable to the panel.
Old 3/2/11, 12:42 PM
Rick Strand's Avatar
Rick Strand Rick Strand is offline
Connector or strain relief
Rick Strand, CPI
CAHPI Associate
Strand Home Inspections Inc.
Calgary, Alberta, Canada
Serving Calgary, Okotoks, Airdrie, Chestermere and Cochrane Alberta
Old 3/2/11, 3:07 PM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is offline
I though bushing was for threaded and grommet for non threaded.
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Donate here:
or send checks to the
Fl Home and Insurance Inspector Chapter
1103 W Hibiscus Blvd Ste 311
Melbourne, Fl 32901
Old 3/2/11, 8:34 PM
Robert Meier's Avatar
I agree with Jim a connector in each panel is required. I am curious about the black conductor with the yellow stripe.
Old 3/2/11, 9:25 PM
Banned
In my area, they are called "box connectors".......appears to be one or 2 missing in your picture.
Old 3/2/11, 11:58 PM
Tracer
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 3/3/11, 12:00 AM
Christopher Currins's Avatar
Originally Posted by jwicklander View Post
Tracer
Would you define that a little more.
Christopher Currins
Certified, Licensed
Old 3/3/11, 5:11 AM
The NEC uses the word stripe to describe that yellow marking on the black conductor. The word tracer is often used as well.
I raised the question as to what type of conductor that is. (I couldn't tell definitively from the photo). From what I've seen this may be type USE conductors, used for underground service entrance laterals, and having a yellow stripe. Type USE condcutors are not permitted to enter into a building and must remain solely on the outside.
ARTICLE 338 Service-Entrance Cable: Types SE and USE
I. General
338.2 Definitions.
Service-Entrance Cable. A single conductor or multiconductor assembly provided with or without an overall covering, primarily used for services, and of the following types:
Type SE. Service-entrance cable having a flame-retardant, moisture-resistant covering.
Type USE. Service-entrance cable, identified for underground use, having a moisture-resistant covering, but not required to have a flame-retardant covering.
338.12 Uses Not Permitted.
(A) Service-Entrance Cable. Service-entrance cable (SE) shall not be used under the following conditions or in the following locations:
(B) Underground Service-Entrance Cable. Underground service-entrance cable (USE) shall not be used under the following conditions or in the following locations:
(1) For interior wiring
(2) For above ground installations except where USE cable emerges from the ground and is terminated in an enclosure at an outdoor location and the cable is protected in accordance with 300.5(D)
Some further information:
http://www.iaei.org/magazine/departm...remise-wiring/
Old 3/4/11, 2:26 AM
And a Bushing or Grommet, is the actual answer to the question.
But I was educated as to the name of the clamp/connector needed in the panel, ty .
New article on protective equipment for inspectors inxil InterNACHI & RealMatcher Blogs 0 8/24/09 11:50 AM
Foundation/wax ring issues? jrapp Interior Inspections 1 1/9/08 2:31 PM
Protective Gear dmacy Electrical Inspections 29 4/10/07 8:39 PM
