Old 4/24/08, 10:00 AM
Ralph Smith Ralph Smith is offline
Default Pushmatic
I came across a pusmatic service panel. Is there recall or other concerns I need to report?
Old 4/24/08, 10:09 AM
Default Re: Pushmatic
One of the more reliable panels out there. Problem is that the breakers are more expensive and more difficult to find.
Old 4/24/08, 11:28 AM
Jeffrey R. Pope's Avatar
Old, obsolete and unreliable. Breakers stick, double-pole breakers will occasionally be half-hot. . .
No recalls, but plenty of issues just the same. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/24/08, 11:53 AM
Jeff, How would you advise your client about these type panels?
Old 4/24/08, 12:16 PM
Maybe a regional thing... never heard/encountered any major problems around here (Chicago area).
Old 4/24/08, 3:06 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have Pushmatic and see them all the time.
Finaly caught Jeff wrong on one.
Here is what I would say.
Pushmatic is reliable but often hard to upgrade.Panel is usually full.
This leaves no room for more breakers.
Old 4/24/08, 8:41 PM
William J. Decker's Avatar
I recommend that the client have the breaker's replaced as they have a habit of not tripping over time. Around here (Skokie) about 40% of the panels are pushmatic (and about 30% are FPE Stab-Lock). It's very easy to find replacments, at least around here.
I try to deterime the age of the breakers, and if they are old, recommend replacment of the breakers.
BUT, I leave it up to the local sparkies. Let them have all the liability for saying it's all right.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 4/24/08, 8:53 PM
relliott's Avatar
We must aggree to dis-agree.
I have never seen them with burns Will.
I was on Keeler this afternoon in Skokie by the way.over a mile south though.
Do not worry as it was just a mortgage shoot.
Poor people could not figure how to turn off there fireplace since they moved in.
I gave them the carbon monoxide drill.
Old 4/24/08, 9:04 PM
Never said anything about burning, Bob. Being very mechanical, they have a habit of not tripping properly, with age.
Will Decker, CMI
Old 4/24/08, 9:13 PM
relliott's Avatar
I was thinking about the fact if they were not tripping when needed , something is overheating.
I have looked up a lot of info on them however, and have not found much to worry about.
Personally I love them.
Found a panel last month that actually had room for more.(that was a first)
I suppose you could go the fuse theory that , if they exist , it is a older system.
Could cost around 1,500 to replace , or they could put in a side car.
Must admit , I would take the conditions in consideration , as to what I would say verbally or in writing.
Old 4/25/08, 12:54 AM
Basically just how I stated it - old, obsolete, breakers that stick, etc. I always recommend upgrading pushmatics to a more modern panels system.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 4/25/08, 1:03 AM
relliott's Avatar
Personaly I like them
Pushmatic Circuit Breakers are now more affordable thanks to Connecticut Electric.The picture shows Interchangeable Pushmatic Circuit Breakers we carry and We Ship Fast!!!
View Shopping Cart
Pushmatic and UBIP Interchangeable Circuit Breakers.
All Breakers are New
Old 4/25/08, 1:21 AM
Russel Ray's Avatar
Ditto down south of you, Jeff. The electricians here also don't like them because of all the problems they have. I consider them in the same category with FPE, Zinsco, and Zinsco/Sylvania.
By the way, I referred an Orange County Realtor to you today.
Old 4/25/08, 1:48 AM
Well, I certainly do appreciate that. Thank you.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 4/25/08, 2:54 AM
relliott's Avatar
There are two Sparky's whose opinion means alot on this forum and they both agree with me.
Marc D. Shunk
4/17/07, 5:50 PM
If PushMatic's were still made today, that would be my brand of choice. I cannot remember ever having replaced a failed PushMatic breaker due to a poor buss connection, as they bolt-on like commercial panels. That was a fine idea, on their part. They were very popular in my area. I have heard of them not turning on or off when you press them, which I have experienced from time to time. Sometimes, it takes a harder press than you'd think. I have never had a PushMatic breaker be in a different state than was indicated in the window, however. It might not have "switched" when I pressed it the first time, but I've found the indicator window to be always accurate as to the true state of the breaker. Admittedly, the design could have been better.
pabernathy
4/18/07, 9:28 AM
Marc,
I think the largest downfall was the size required on THOSE specific designs.....the sticking issue is normal when you talk about something 30 years old and dust and dirt and well......TIME......we all get a little "STICKY" with time.....
But probably the reason we don't see a HUGE out cry about them is that they were SOLID.......and with a few problems but overall worked very well....
Heck....ALL the manufacturers have had issues over the years.....
Pushmatic and service size help cbrands Electrical Inspections 10 9/23/07 10:55 PM
ITI Pushmatic panel prussell Electrical Inspections 6 4/30/07 2:43 PM
PushMatic Circuit Breakers lewens Electrical Inspections 5 8/17/06 10:59 AM
Pushmatic panel orientation bsmith Electrical Inspections 7 2/2/06 11:01 PM
