I'm pretty sure quadruple taps are not allowed
If both wires can be well secured without touching each other, it probably was designed for a double tap.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Jay, you are right that is multi tapping is a big concern, pushmatic panels are also very old and hard to get parts for, it was talked about not too long ago.
Chuck Crooker I.M.M., Canadian Home Inspectorhttp://www.crookerhancox.com "Not just an inspection, an Education!!!"
Good call some do not like Bulldog pushmatic panels . I have no big concern with them even if they are over 40 years old . .You can still buy new breakers for them in Canada Very expensive . Roy sr |
Hi to all,
Pushmatic breakers are not rated for double taps. One of the problems with these panels is that they have relatively little capacity for breakers (typically 20, less if double pole 240's are needed) this was fine when they were installed 40 odd years ago but modern power requirements tend to need more. this is why you'll often see double taps on older panels. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Would it not be best for the client to just upgrade the whole panel instead of a sub-panel, the man's there and got the parts$$$$
yes I tend to agree with you, if it were my home I'd go that route and install a larger modern panel, the cost difference is probably around $5-600. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Agreed...Nothing about that LUG will allow Multi-Taps.
Paul W. Abernathy |
Here is the one I came across recently. . .
Seven switches for service disconnect. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
