Should I or would you be concerned about a 10 degree temp differential between the two legs on a 240 volt double pole breaker Yes or no please
| Need a home inspection in Indiana? Check out InterNACHI's listing of Indiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Yes.
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
No. I wouldn't be too concerned because 240V loads are not always perfectly balanced and 10 degrees F isn't very much of a difference. You might first want to look at what type of load it is. You could also put a clamp-on Ammeter on each leg to see if there is much of a difference between the two legs. Also look for loose connections. If the load is a 240V heating element or something similar, the legs would have exactly the same current flowing. One being hotter than the other would suggest a loose connection. One the other hand, some appliances have both 120V and 240V loads. At any given time, one leg could be carrying more or less current than the other so one leg could be hotter than the other.
BestInspectors.Net
& Real Estate Training Academy Inspection Report Software for Windows - iOS - Mac - Android Continuing Education Home and Commercial Building Inspection - Skilled Trades – Real Estate – Appraisal – NFPA 921 http://www.bestinspectors.net est. 1992 |
Any way you look at it, it's a possible deficiency that warrants investigation. BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging Last edited by ldapkus1; 7/9/11 at 9:18 PM.. |
The appliances that have 120 volt circuits are mostly for clocks and timers that virtually have no amp draw not enough to effect the infrared temp Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
I would need to be there to make the call.
No big deal I agree with George .
I think you will find this is very common . Roy Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
one yes and two no's Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
yes If we are talking about a feed to a sub panel
Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. Last edited by rcooke; 7/9/11 at 9:50 PM.. |
I did not say what the breaker was feeding but it was not feeding a sub panel I will give more specifics after I collect a few more yes or no's
The motor on a dryer is 120.
If it is feeding a balanced load then I would expect they should both be very close to same temp.
BTW: Is that a split buss I see? What kind of load is on each leg? Tell me more about that hot spot on the buss. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX Last edited by cevans; 7/9/11 at 10:39 PM.. |
| Question for all... | Bob Hopton-Jones | General Inspection Discussion | 9 | 4/6/07 7:43 AM |
| Basement Bathroom Venting Question | Sean M. Jeric | Plumbing Inspections | 4 | 3/20/07 11:56 PM |
