Question: How do you test a GFCI receptacle?
1. The push button on the GFCI receptacle 2. Ohm meter 3. GFCI testing device 4. Multimeter Answer No. 1, was identified as being incorrect? Is there something being missed here? What is the correct answer? http://www.ul.com/consumers/groundfault.html Product Safety Tips: GFCIs -- A SMALL INVESTMENT, A BIG LIFESAVER UL Recommends Regular Testing of GFCIs December 20, 2003: Underwriters Laboratories periodically revises requirements in its Standards for Safety to harmonize with international requirements, address code and safety issues, and accommodate new product developments as applicable. UL has adopted new and revised requirements for Ground-Fault Circuit-Interrupters (GFCIs) that become effective January 1, 2003. Among others, these requirements include enhanced requirements for immunity to voltage surges, resistance to moisture and corrosion, reverse line-load miswiring, and resistance to environmental noise. Though products meeting these revised requirements will soon enter the marketplace, they are not required to have any special markings to distinguish them from models made prior to January 1, 2003. Models of GFCIs Listed by UL that were manufactured and labeled prior to January 1, 2003 still may appear in the marketplace after January 1, 2003, and until such time as old stocks of GFCIs become exhausted. Ground fault circuit interrupters (GFCI) can help prevent electrocution inside and outside the home. GFCIs are an effective means of protecting against electrical shock, however, they must be tested regularly -- UL recommends once a month -- to verify they are working properly. "Ground faults" are often the result of damaged appliance cords or consumers who use electrical products in wet environments, such as bathrooms or swimming pool decks. By installing GFCIs in every home in the United States, the U.S. Product Safety Commission (CPSC) estimates that more than two-thirds of the approximately 300 electrocutions occurring each year could be prevented. The advantage of using GFCIs is that they detect even those amounts of electricity too small for your fuse or circuit breaker to activate and shut off the circuit. Like all products, GFCIs can be damaged. GFCIs damaged by lightning or electrical surges may fail to provide adequate protection. A simple test once a month and after any violent thunderstorm should be conducted. To properly test GFCI receptacles in your home:
"GFCIs are proven lifesavers, however, consumers need to take a few minutes each month to do this simple test. By taking action, you can help protect your family from the risk of electric shock," says John Drengenberg, UL Consumer Affairs Manager. Several types of GFCIs may be installed in/around your home. Look for the UL Mark on GFCIs when purchasing them or when specifying the product to your electrician. Wall Receptacle GFCI -- This type of GFCI -- the most widely used -- fits into a standard outlet and protects against ground faults whenever an electrical product is plugged into the outlet. Wall receptacle GFCIs are most often installed in kitchens, bath and laundry rooms, and out-of-doors where water and electricity are most likely to be in close proximity. Circuit Breaker GFCI -- In homes equipped with circuit breakers, this type of GFCI may be installed in a panel box to give protection to selected circuits. Circuit breaker GFCIs should also be checked monthly. Keep in mind that the test will disconnect power to all lights and appliances on the circuit. Portable GFCI -- A portable GFCI requires no special knowledge or equipment to install. One type contains the GFCI circuitry in a self-contained enclosure with plug blades in the back and receptacle slots in the front. It can then be plugged into a receptacle, and the electrical products are plugged into the GFCI. Another type of portable GFCI is an extension cord combined with a GFCI. It adds flexibility in using receptacles that are not protected by GFCIs. Portable GFCIs should only be used on a temporary basis and should be tested prior to every use. Underwriters Laboratories Inc. (UL) is an independent, not-for-profit product safety certification organization that has been testing products for more than a century. More than 16 billion products bearing the UL Mark enter the marketplace every year.
Joe
I have been either using the test button on the GFCI or my testing device. Is there a better way to test the GFCI's and would AFCI's be the same? Thanks Dave |
Brian:
Opps, the link I meant was on the NACHI test page, not the link here. I don't remember what question number is was. Look for it and maybe is is fixed now. PS: Who writes these tests and who checks the answers for accuracy? Subject Matter Expert - SME The Subject Matter Expert is that individual who exhibits the highest level of expertise in performing a specialized job, task, or skill within the organization. An SME might be a software engineer, a helpdesk support operative, an accounts manager, a scientific researcher: in short, anybody with in-depth knowledge of the subject you are attempting to document. You need to talk to SMEs in the research phase of a documentation project (to get your facts straight) and you need to involve them in the technical validation of your drafts (to make sure that your interpretation of information matches theirs). Last edited by jtedesco1; 9/30/06 at 12:08 PM.. |
Probably some "expert" or another Joe.
And spare us the 6 sigma, what are you now Dr. Demming?
Whats next x bar and r charts? |
mcraig is a non-member guest and is in no way affiliated with InterNACHI or its members.
I think 6 sigma went the way of the big corporations that expoused it's merits. IBM took our 6 sigma hats away and gave us the MDQ hat (Market Driven Quality) The new "guru" was Sam Walton not Sony. The motto was don't give the customer any more quality than they are willing to pay for.
Brian: I used the link above to identify a SME. In my training areas around the USA I am asked to satisfy the SME requirements. I called this "SME" link to the attention of those here who may have understood the acronym during their professional careers. I am not affiliated with the 6 sigma stuff. I was evaluated during a recent seminar while in Pottstown, PA and that Utility company has sanctioned me as an SME, so now I can expect that future work assignments will be coming my way. I will be interested in your evaluation of the seminar planned for your chapter sometime soon. I was hoping to be there too, but have other business to attend too. |
Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
There was once an Admiral (his name escapes me now) who was introduced as an "expert on Russia and the Soviet Union" to which his first reply, once he got on the podium was, "There is no such thing as an expert, especially about Russia, only varying degrees of ignorance."
From what I remember, a GFCI can be installed in such a way that the test button will trip but still provide power to the circuit. Where a GFCI testing device is independent of the intergrated circuit of the plug and gives more valid testing of the circuit. I'm not 100% sure, but I remember reading something about this in testing procedures. |
George,
If you pigtail the circuit downstream to the actual LINE side instead of the load side before you make the connection to the line inputs ( again via pigtail connection ahead of the actual connection )......the GFCI will trip but the down stream will remain live...However, if offers no protection to the circuit downstream...... Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
Thanks for clearing that up for me. |
| Final review of Newman's radon references! | Caoimhín P. Connell | Ancillary Inspection Services & Additional Topics | 12 | 10/4/08 1:23 PM |
| Good test question for CMI | cbottger | Inspecting HVAC Systems | 24 | 6/14/07 11:28 AM |
| Inspection of HVAC by an area inspector. | dmcauley | Inspecting HVAC Systems | 13 | 3/21/07 12:03 PM |
| As promised - Review of Newman's first radon study | Caoimhín P. Connell | Ancillary Inspection Services & Additional Topics | 7 | 1/24/07 1:21 PM |
