Old 10/18/06, 10:15 PM
John W. Springstead's Avatar
John W. Springstead John W. Springstead is offline
Default Question for sparkies!
Ran into this today. It appears the connection on one side of the entrance cable is melted, as it is inside the main panel. What might cause this and how serious is it?? Thanks
question-sparkies-anderson7-036.jpg   question-sparkies-anderson7-037.jpg   question-sparkies-anderson7-054.jpg
John Springstead
Home Inspections of USA
1752 N.E. Torch Lake Dr.
Central Lake, MI 49622
1-231-544-8016 office
1-231-544-6001 fax
www.homeinspectionsusa.us
Old 10/18/06, 10:30 PM
Ted Allen Ted Allen is offline
Default Re: Question for sparkies!
Looks like a bad crimp by the AHJ. Power company.............
Old 10/18/06, 10:31 PM
Jeffrey R. Pope's Avatar
You're no sparky Todd
My thought was a poor connection as well, but I ain't no sparkie neither. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/18/06, 10:43 PM
Hey Pope , stop beating me up. I have made a connection or 2 in my time LOL
Old 10/18/06, 11:02 PM
Pierre Belarge Pierre Belarge is offline
Please Note: Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree with the "non-sparkee"
This type of connection is not always performed by the POCO. Sometimes the conductor is not always inserted far enough inside the crimp connector. This may be the case here. The picture of the inside location is hard to see, so I am not too sure what may have caused that situation.
Old 10/18/06, 11:22 PM
bkelly1's Avatar
bkelly1 bkelly1 is offline
Please Note: bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is the third picture the main ?
Old 10/18/06, 11:34 PM
Unmoderated Guest
I found a crimp the other day that looked exactly like that one.
Also, I have had to replace more than one panel in my day for exactly the same reason as pic #3. Once the buss starts to pit and/or overheat there is no turning back.
Old 10/18/06, 11:37 PM
Joseph Hagarty,  CMI's Avatar
Lightening Strike?
Joseph P. Hagarty, CMI
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 10/18/06, 11:41 PM
Roy D. Cooke, Sr's Avatar
Originally Posted by jhagarty
Lightening Strike?
That was my first though but I have never seen lightening being selective it would take out every thing including the mast.
I think it was a previously reported loose ar incorrect joint .
Roy Cooke
Old 10/19/06, 8:46 AM
Paul W. Abernathy's Avatar
I guess it is entirly possible it was a lightning strike...but I would also not rule out a overloaded breaker that overheated and melted the back plastic holder. on the connection at the drop.....as others have stated it could simply be a poor connection which is a compression crimp done by the POCO...not the electrician in most all cases....can't say all as who knows is some little counties somewhere out their.....lol
My experience is on a lightning strike it does not single out a simple breaker contact point like this image from what i can tell....it usually melts down a larger area if a direct hit......did the home not have a proper GEC and System on it?
Anything entirly possible...one this is for sure....regardless it is must be replaced at this point and reported as such.
Paul W. Abernathy,CMI,CPI,CME
Old 10/19/06, 9:14 AM
Thanks all! I had suggested further evaluation and replace/upgrades recommended.
Current 100 amp., 24 breakers with 4+ doulble taps, + feeding one 60 amp. sub.
John Springstead
1-231-544-6001 fax
Sump Pit/Pump Question Joey D'Adamo Plumbing Inspections 4 11/26/08 2:04 PM
Interesting Question? jmckenna1 Miscellaneous Discussion for Inspectors 9 11/25/07 2:13 PM
WA State Legislative update hmiller Legislation, Licensing & Legal Issues for Inspectors 153 5/5/07 12:55 AM
Rule of Thumb A/C sizing question from Practice Exam gliebig Inspecting HVAC Systems 9 5/25/06 2:38 AM
