Old 2/2/06, 12:21 AM
John W. Springstead's Avatar
John W. Springstead John W. Springstead is offline
Default Question on sump pump alarm wiring.
Ran across this today. Someone wired in an alarm for the sump pump,
( after final inspection I believe ) and used the white for the feed.
Bottom left breaker.
It's kinda odd, it enters box from below, exits out side to alarm light.
Shouldn't they have used black for power? and how would you comment?
Thanks!
John Springstead
Home Inspections of USA
1752 N.E. Torch Lake Dr.
Central Lake, MI 49622
1-231-544-8016 office
1-231-544-6001 fax
www.homeinspectionsusa.us
Old 2/2/06, 2:14 AM
Default Re: Question on sump pump alarm wiring.
If this is a basically switch loop you do use the white for the hot "input", although it should be reidentified.
The thought is down stream of the switch the black "output" will be the hot.
Hot Tub wiring question? Steven Brewster Electrical Inspections 16 10/25/07 12:55 AM
sump pump discharge vwood Plumbing Inspections 10 6/18/07 11:59 PM
Sump pump I get all of the good ones cbottger Plumbing Inspections 5 5/29/07 3:48 AM
Sump pump question dmacy Plumbing Inspections 5 5/11/06 2:28 AM
Question on my heat pump dbush Inspecting HVAC Systems 7 3/12/06 1:15 AM
