| Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera. |
I know that a 120 volt swimming pool light has to be on a GFCI, but what about a 12 volt light. Does the power to the transformer have to be GFCI protected? This is the pool panel I inspected yesterday. the transformer is located inside the panel but the light is only 12 volts.
Robert Sole 407-637-7288 Serving the Orlando Florida area including Orange, Seminole, Northern Osceola and Southwestern Volusia Counties. RobertSole@REMinspections.com REMinspections.com OrlandoHomeInspector.net |
| Find an InterNACHI certified West Virginia Home Inspector (and anywhere else in North America) |
No need for GFCI if less than 15V.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ℠ Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 9/30/09 at 5:36 PM.. |
That has been my opinion also. I didn't feel that it wa a problem with the low voltage. It kept bugging me though so I wanted some confirmation. Thanks for the response.
This may assist you :
(3) GFCI Protection, Relamping. A ground-fault circuit interrupter shall be installed in the branch circuit supplying luminaires operating at more than 15 volts such that there is no shock hazard during relamping. The installation of the ground-fault circuit interrupter shall be such that there is no shock hazard with any likely fault-condition combination that involves a person in a conductive path from any ungrounded part of the branch circuit or the luminaire to ground. When dealing with those types of luminaries the key is in the transformer: (2) Transformers. Transformers used for the supply of underwater luminaires, together with the transformer enclosure, shall be listed as a swimming pool and spa transformer. The transformer shall be an isolated winding type with an ungrounded secondary that has a grounded metal barrier between the primary and secondary windings. Paul W. Abernathy,CMI,CEI,CEPE NECŪ Consultant/Columnist www.twitter.com/ElectricalGuru - ICC & IAEI Certified Electrical Inspector - ICC & IAEI Certified Electrical Plans Examiner - Look for my article in the Nov/Dec 2009 IAEI Magazine - 2007 "Top Gun" Winner - Mike Holt Enterprises " visit www.TheElectricalGuru.com Today !" |
| Let's talk ESOP | rcooke | General Inspection Discussion | 231 | 2/22/08 9:55 PM |
| It's time for Professional Pool Inspections | Revel L. Thom | Ancillary Services & Additional Topics | 13 | 7/26/07 11:50 AM |
| Swimming pool Plaster | phughes | General Inspection Discussion | 6 | 2/26/06 2:47 PM |
