Old 7/21/10, 12:56 PM
pnarron pnarron is offline
Default Quick help
What could be the cause of open grounds on outlets and gfci not working on exterior,garage and masterbath. The gfci worked fine in hall bath. (The outlets showing open ground were on 1 side of hose only. I did tell client to have an electrican come out and ckeck it out. ( House is an frinds son)
Need a home inspection in South Carolina? Check out InterNACHI's listing of South Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/21/10, 1:02 PM
Jeffrey R. Pope's Avatar
Default Re: Quick help
Grounding conductors not present or not connected, and defective or mis-wired GFCI receptacles.
That's the best answer you can hope for with the limited information you have provided.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 7/21/10, 1:03 PM
Jim Port Jim Port is offline
Unmoderated Guest
Is there a chance that they are downstream of the hall bath GFI?
Old 7/21/10, 1:28 PM
I had did this house 5 weeks ago and the loan officer called me about it 15 min ago. I checked the report and the main panel had breakers that were not rated for the panel and lose breakers as well. I talked to the client a couple min ago and he said that he was going to have an electrican come out when the house was his. I told him that the lender was not going to approve it because the appraser had the gfci not functional on his report; so he is going to have it fixed, Thanks for your help.
Tricks with Quick Flir Quick Report 1.2 and Online Viewer cevans Thermal Imaging, Infrared Cameras & Energy Audits 2 2/28/10 1:31 PM
Does anyone use quick books? ejones2 Inspection Hardware, Software & Publications 25 2/18/10 10:21 AM
Two Quick Questions On Receptacles rtrain Electrical Inspections 7 11/27/07 11:24 PM
Thanks for the quick response cpatzman Miscellaneous Discussion for Inspectors 6 6/11/06 10:54 PM
