FPE panel at todays inspection. Panel was rated for 200 amp max. (according to sticker on inside) Service was 3/0 awg Aluminum. My sheet tells me this is 175 amp rated service entrance conductor. Now, FPE panel typically don't have a main service disconnect, so am I too assume that this is 175 amp service?
Thanks ahead of time........
Rick Slocum NACHI # 04072697 Elizabeth CO 80107 ABSOLUTE Home Inspection Service Last edited by rslocum; 7/4/07 at 2:33 PM.. |
The service capacity (important inclusion) would be the lesser of the rated components, in this case, 175 amps.
Thank you Jeff , I appreciate the info. I haven't run into anything but the split buss type. Your always a great source of info !
Rick Slocum NACHI # 04072697 Elizabeth CO 80107 ABSOLUTE Home Inspection Service |
| Quick and easy trap question | Danny Castellano | Plumbing Inspections | 4 | 8/14/06 1:17 PM |
| HSPF - quick question | rray | Inspecting HVAC Systems | 5 | 7/17/06 5:01 PM |
| Quick question about double-wide plumbing | mmorgan | Plumbing Inspections | 1 | 6/11/06 7:52 PM |
