Old 12/1/10, 11:08 AM
Gregory Allen's Avatar
Gregory Allen Gregory Allen is offline
Default Range receptacle box
This just looks wrong to me,any comments?
Greg Allen,Certified Home Inspector
NC License# 2239
NACHI ID# 05082583
Buyers Protection Group
Apex, NC 27502
"Greater Raleigh-Durham Home Inspections and Radon Mitigation Services"
http://homeinspectorguy.com
"Paying attention to simple little things that most men neglect makes a few men rich" Henry Ford
Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/1/10, 11:15 AM
Joe Funderburk, CMI's Avatar
Default Re: Range receptacle box
I'll let a sparky address, but I'm pretty sure that blue box is not listed for use with 220 VAC.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 12/1/10, 4:11 PM
Jim Port Jim Port is offline
Unmoderated Guest
Not enough detail is shown to see if that box has the proper clamp for that size cable. I don't know why someone would think a two gang box could not be used on a 240 volt circuit, or maybe that blue is only for 120 volts.
Old 12/1/10, 5:24 PM
Robert Meier's Avatar
Unless the box is improperly sized or the cable is subject to physical damage I see nothing wrong with it. Maybe someone could say that the box is not installed as per it's listing but to me that's a stretch. The receptacle used as a disconnect for an electric range is required to be accessible after the range is installed. This is usually by removing the bottom drawer on the range.
422.33 Disconnection of Cord-and-Plug-Connected Appliances.
(A) Separable Connector or an Attachment Plug and Receptacle. For cord-and-plug-connected appliances, an accessible separable connector or an accessible plug and receptacle shall be permitted to serve as the disconnecting means. Where the separable connector or plug and receptacle are not accessible, cord-and-plug-connected appliances shall be provided with disconnecting means in accordance with 422.31.
(B) Connection at the Rear Base of a Range. For cord-and-plug-connected household electric ranges, an attachment plug and receptacle connection at the rear base of a range, if it is accessible from the front by removal of a drawer, shall be considered as meeting the intent of 422.33(A).
Old 12/1/10, 6:01 PM
Robert Ernst Robert Ernst is offline
It would have to be a 20 cuin box or bigger I believe. I don't think that type plastic boxes are usually allowed to be surface mounted and you also have unprotected non-metallic cable there. I would refer it out to a licensed Electrician. They could replace that with a surface mount receptacle and cover the wire with flexible conduit through the floor.
Old 12/1/10, 6:20 PM
Perhaps I misspoke about the listing being due to the voltage or amperage. But you can bet there's a reason why it's not acceptable or you'd see them all them time like that.
Because it's a floor mounted box, it would have to be specifically listed for such use. What you normally see is a much more rugged type of plastic. That blue box is very likely to be cracked if the range hits it the wrong way. If I were the AHJ, I'd make the electrician prove the box is listed as acceptable for a floor mount.
Theodore Roosevelt
Joe Funderburk, CMI
Old 12/1/10, 7:38 PM
Unmoderated Guest
Just for the sake of argument, I would say the box is not mounted on the floor. It is nailed to the framing near the floor.
The box, regardless of style, is told where to be installed in the manufacturers instructions to avoid any conflict with hitting any part of the stove to avoid any damage.
I would have expected to see either a surface mount receptacle or a metal box with the correct coverplate, but don't see any reason to reject this install.
That box is probably a 34 cubic inch box. A 20 cubic inch box would still be a single gang box.
Old 12/1/10, 8:11 PM
Even if this were 6/3 NM cable the box would need to be 38 cu inches, not overly large for a two gang box. Here's the calculation:
3-#6 conductors * 5 cu in/ conductor= 15 cu in
1-#8 conductor * 3 cu in/conductor = 3 cu in
1-2 gang device * (2*5) cu in/gang= 20 cu in
Total: 38 cu inches minimum box size.
Old 12/1/10, 10:27 PM
I came up with 20 cu in but this says the calculator states 23 cu in. They make extra deep plastic boxes that are allot thicker. The wires can fit into a deep box but I still don't like exposed plastic boxes unless they are meant to be connected to conduit. Here is a handy link.
http://www.constructionmonkey.com/ca...l/boxfill.aspx
Old 12/2/10, 5:01 AM
What size conductors/number of did you use to come up with 20 cu in?
I tried that calculator and algorithm for #6 conductors on a device is incorrect.
Old 12/2/10, 4:14 PM
I was using #6 and I do think the calculator is wrong. I used another program I have and it's different at 27.25.
3-#6=15 1-Divice (2x conductor)=10 and 1-#12 ground 2.25.
Old 12/2/10, 11:55 PM
My apologies, I missed the fact that this was single gang box and a #10 EGC. Usually the EGC in a cable containing #6 conductors is a #10. Therefore my calculation should have been:
1-#10 conductor * 2.5 cu in/conductor = 2.5 cu in
1-1 gang device * (2*5) cu in/gang= 10 cu in
Total: 27.5 cu inches minimum box size.
Old 12/3/10, 4:57 PM
Brian E. Kelly's Avatar
Don't like the exposed cable.
Old 12/8/10, 10:29 PM
I guess if you really want a reason to give them a headache then you could write down the bold/underlined below.
334.15 Exposed Work.
In exposed work, except as provided
in 300.11(A), cable shall be installed as specified in
334.15(A) through (C).
(A) To Follow Surface.
Cable shall closely follow the surface
of the building finish or of running boards.
(B) Protection from Physical Damage.
Cable shall be
protected from physical damage where necessary by rigid
metal conduit, intermediate metal conduit, electrical metallic
tubing, Schedule 80 PVC conduit, Type RTRC marked
with the suffix -XW, or other approved means. Where passing
through a floor, the cable shall be enclosed in rigid
with the suffix -XW, or other approved means extending at
least 150 mm (6 in.) above the floor.
However, if installed properly I would call it a non-issue but since we are all doing the calculations and all that jazz...
Paul W. Abernathy
Outlet behind cooktop srowe Electrical Inspections 12 5/17/08 2:02 PM
Electric Range Receptacle jtedesco1 Electrical Inspections 4 5/16/08 9:29 PM
Range hood Ian Gills Electrical Inspections 3 2/2/07 8:14 AM
