Old 11/16/06, 10:35 AM
rarmstrong1 rarmstrong1 is offline
Default Rate This Split Bus Panel
A split bus panel box has a rating of 150 Amps.
The SE cable is 2/0 AL.
The four 240 breakers at the top half are rated 60,40,30 and 60 for the main lighting circuits, which are breakers at the bottom half of panel.
Switching the four 240 breakers would cut all power to house.
Is this a 150 Amp service or something else? 60 Amps?
Old 11/16/06, 11:44 AM
Jeffrey R. Pope's Avatar
Default Re: Rate This Split Bus Panel
150 amp capacity.
Its capacity is limited by the size of the SEC and the rating of the panel.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/16/06, 7:10 PM
Thanks Jeff
Old 11/17/06, 6:41 PM
Paul W. Abernathy's Avatar
Yep..on the split buss you have to use the factors present and in your case the Panel Rating and Conductor Size was the determining factor here.
Always nice having the POPE around....
Paul W. Abernathy,CMI,CPI,CME
Old 12/3/06, 4:44 AM
egarcia1's Avatar
egarcia1 egarcia1 is offline
Let me see if I understand , its had 150 amp capacity but the #2al is only good for 100 amps correct? (I am a newbie soaking up everything you guys say!)
Ernie Garcia
(719)821-6211
Builders Eye Home Inspections LLC.
builderseyehomeinspections.com
email me
Old 12/3/06, 7:40 AM
Ernest, if you look at post #1 again, Robert calls out 2/0 AL SEC which is good for 150 amps not #2 AL SEC which is only good for 100 amps, in this instance.
But be careful you don't soak up everything we say on this BB , there are some things worthy of being ignored.
Larry Kage, CMI
231 929 3525
Old 12/3/06, 9:34 AM
Cool Re: Rate This Split Bus Panel
The attached Table supports the comments by lkage related to Type SE 2/0 Aluminum, etc.
The light blue commentary is in part from the handbook.
Keep in mind today's rules related to the types and sizes and new rules for "SR" marking per UL requirements.
Old 12/3/06, 10:03 AM
Carla Horne's Avatar
Carla Horne Carla Horne is offline
with all of Jeff's knowledge passed on here I think we should
rename him Pope Jeff!
thanks Jeff for all that you contribute!
CJ
Old 12/3/06, 1:03 PM
Pope Jeff...I like it.....are you saying jeff should drop the Mr. Zinsco label....noooo....dont say it's so....
Old 12/3/06, 1:36 PM
egarcia1's Avatar
Ah 2/0al oops, I am learning a bunch here guys thanks for sharing!
Ernie Garcia
(719)821-6211
email me
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 8:28 PM
Split Buss CH panel w/Double tapped mains gwilcox Electrical Inspections 5 7/18/07 8:14 AM
Murray Split Main Panel jhagarty Electrical Inspections 15 2/18/07 4:26 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 10:02 PM
Bad electrical problem Pest Guy Electrical Inspections 4 1/20/06 10:26 PM
