Old 12/16/08, 10:16 AM
Vince Santos's Avatar
Vince Santos Vince Santos is offline
Default receptacle
What do you typically recommend when you come across this type of installation?
Receptacle above baseboard heating. This one is a little different in that it's actually blocked as well.
Vince Santos
StepByStep Home Services LC
(734) 748-9584
Providing Home Inspection Services to Southeast Michigan
facebook
ITA Trained and Certified
Old 12/16/08, 10:22 AM
James F. McKee's Avatar
Default Re: receptacle
Repair by a qualified electrician....nice picture Vince
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 12/16/08, 10:23 AM
bdoles2's Avatar
bdoles2 bdoles2 is offline
As a minimum I'd recommend removal of the outlets, to be replaced with a blank double gang cover. This will eliminate even the thought of plugging in something.
And as James states, to be done by a licensed electrician.
Old 12/16/08, 10:26 AM
Michael Larson's Avatar
Depends on whether the baseboard is electric or hot water.
Of course the half covered receptacles are a problem worth noting.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 12/16/08, 10:29 AM
Wayne B. Wilson's Avatar
There should be no outlet above a heater
Old 12/16/08, 10:31 AM
The baseboard heat in this area was electric.
Vince Santos
(734) 748-9584
facebook
Old 12/16/08, 10:45 AM
Then removal is the only option.
This does not apply to baseboard hot water systems.
Michael Larson
Hudson, WI
InspectraPro
and
Old 12/16/08, 7:29 PM
Marc D. Shunk's Avatar
Banned
You could actually enhance the nature of the hazard if you step into recommending how the hazard is to be remediated. If this receptacle is installed to satisfy spacing rules, summary elimination of the receptacle is not the fix for the hazard. Removing the receptacle and installing two more, each at the outboard ends of the heater, is more likely the fix the electrician will have to do.
Old 12/16/08, 7:43 PM
I'm not sure what you are saying Marc.
Has is ever been code to have electrical outlets above electric baseboard?
Michael Larson
Hudson, WI
InspectraPro
and
Old 12/16/08, 7:45 PM
Banned
No, it's never been in the code, per se - save for 110.3(B) which is a general rule that manufacturer's rules be followed. All electric baseboard heaters have instructions that forbid a receptacle over them. Even if they didn't, it's at least a stupid place for a receptacle. You're allowed to call out stupid things.
Old 12/16/08, 7:46 PM
Banned
Was it the spacing rules that have you mixed up, maybe?
Old 12/16/08, 7:54 PM
I am very familiar with the spacing rules.
The heater was likely installed after construction in an unacceptable manner.
I'd rather have no receptacle there and violate the spacing rule than have the fire hazard of a cord draped over the heater.
Either way it needs to be called out. Remove one or the other.
Michael Larson
Hudson, WI
InspectraPro
and
Old 12/16/08, 8:00 PM
Christopher Currins's Avatar
So you don't agree with Mark on replacing instead of removing? That is what I would recommend. You even said the rec. was most likely there before the heater.
Christopher Currins
Certified, Licensed
Proudly serving the Illinois Metro-East
Illinois Home Inspector
Top 5 Tasks for January
Old 12/16/08, 8:02 PM
Banned
I'm puzzled why you'd recommend any particular repair at all. Wouldn't the more prudent approach be to simply point out that it's being there is a hazard, and recommend an electrician correct it? Whether the electrician simply blanks it off or whether he blanks it off and installs another 1 or 2 outside of the heater's length should be up to someone besides the home inspector. Sorry, but I get a little cranked up when a home inspector attempts to tell the homeowner or buyer how I ought to effect the repair.
Old 12/16/08, 8:21 PM
Hey Marc, remove the outlet or remove the heater. I don't care.
And please get off your high horse.
Michael Larson
Hudson, WI
InspectraPro
and
Join Cu to Al at the receptacle screws? jkogel Electrical Inspections 11 9/19/08 4:22 AM
Microwave receptacle jwardenski Electrical Inspections 17 9/9/07 8:18 PM
What's This Receptacle For? cmettel Electrical Inspections 7 5/25/07 8:35 AM
Bedroom receptacle dnasser Electrical Inspections 9 4/16/07 11:33 AM
Online Code Check- Reference pabernathy Electrical Inspections 31 11/9/06 4:39 PM
