Old 12/8/11, 8:04 PM
Chad E. Nounnan Chad E. Nounnan is offline
Default receptacle
Can a receptacle be located behind an air conditioner?
Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/8/11, 8:07 PM
Joseph M. Whitt Joseph M. Whitt is offline
Default Re: receptacle
or anywhere else one wants to put one. If it is a GFCI I would point out that it would be hard to test.
Mike Whitt
Contractor/Instructor
Old 12/8/11, 8:15 PM
It tested ok. I thought that would be the answer, thanks.
Old 12/14/11, 8:53 PM
And I would point out also that if it is a GFCI and it is behind an Air Conditioner in a manner that I can't get to it (for what ever reason) that it is declared not readily accessible then it would need to be protected upstream or with a GFCI Circuit Breaker that was readily accessible...(but that's in the 2011 NEC...not really something you guys face unless you are doing new construction)
Paul W. Abernathy
Old 12/14/11, 9:04 PM
Robert Meier's Avatar
The new (2011) readily accessible requirement for GFCI receptacles will also apply to devices installed for garage door openers in garage ceilings. If the receptacle cannot be reached from the floor without the use of a ladder or some other device then the GFCI protector must be installed elsewhere. I can barely reach the test button from the floor with an 8' ceiling. IMO anything above 8' would require a different setup. A short inspector might lower the threshold to 7'.
Old 12/14/11, 9:09 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Nice lol
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/14/11, 9:56 PM
Jim Port Jim Port is offline
Unmoderated Guest
They ruled out short inspectors for the whirlpool tubs too. I guess they got tired of bumping their heads behind the skirting.
Laundry room, wash tub receptacle srowe Electrical Inspections 2 11/10/10 7:40 PM
What would this receptacle outlet be used for? kluce Electrical Inspections 11 6/11/09 10:32 PM
Microwave receptacle jwardenski Electrical Inspections 17 9/9/07 7:18 PM
Online Code Check- Reference pabernathy Electrical Inspections 31 11/9/06 3:39 PM
