Quote:Receptacles Mounted on Covers. Receptacles mounted to and supported by a cover shall be held rigidly against the cover by more than one screw or shall be a device assembly or box cover listed and identified for securing by a single screw.
I might also be concerned about the way the box was secured to the surface it was mounted on. Be sure to check for proper support. PS: These types of raised, or flat cover mounted receptacles also require an equipment bonding jumper (green or bare) pigtail to be connected to the green screw on the receptacle, and to a threaded screw hole in the box (sheet metal screw is not permitted) or to a LISTED grounding clip. -- |
It is very common to find receptacles that were attached by a single screw. This is a fairly new manufacturing standard that has the provision for top and bottom yoke screws. A <silly>question could be asked if it is a 110.3(B) to drill holes and add the extra screws on an older raised or flat cover. I still have several of the old style in my junk box, complete with U/L stamps.
I'm sure the HIs see them every day |
| Receptacles not having acceptable blade retention | jtedesco1 | Electrical Inspections | 12 | 1/28/12 8:40 AM |
| Two Quick Questions On Receptacles | rtrain | Electrical Inspections | 7 | 11/27/07 11:24 PM |
| Supply Plenum Mounted High in Attic | Skip Erwin | Inspecting HVAC Systems | 6 | 4/7/07 10:07 AM |
| 2 Prong Receptacles | dnasser | Electrical Inspections | 5 | 2/26/07 11:24 AM |
| open ground on 3 garage receptacles | dnasser | Electrical Inspections | 14 | 10/30/06 5:53 PM |
