Recessed Lighting in Garage Ceiling
Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member Last edited by jhagarty; 2/18/08 at 5:34 PM.. |
There are fire rated recessed cans on the market (they look like a big drywall box), but I'd sorta doubt that's what you're dealing with. Might want to look into that a bit if those cans are a penetration in a rated assembly.
Is there dwelling space above the garage? That would require a fire rated ceiling
I agree.
From what I know, with no living space above, the fire rated ceiling needs only to be 8 feet(?) out from the dewlling partition. |
Here is a pic from today's inspection
************************************** Shawn Rowe, CMI HomeFirst Inspection Services, LLC - InfraRed Specialist (Level 1 & Building Science certified) - Code Certified Residential Building Inspector - Certified Master Inspector -- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties -- |
Interesting that those lighting penetrations are fire rated, but the hvac transition ducts are not. Either the electrician is wasting money, or the hvac people dropped the ball.
I also see the phone and cable running right next to the 120. Not a violation, but certainly poor practice. Current BICSI standards would require the phone and cable to be 12" away from line voltage conductors when running parallel, and 3" away when crossing at a perpendicular. Last edited by Marc D. Shunk; 6/15/07 at 9:47 PM.. |
I am actually surprised too but not for the same reasons you are. The photos are at the second floor attic (not above the garage) but there is a third story "tower" which now classifies the home as a 3-story. Ok, here is the surprise, the current local codes states that there needs to be a fire suppression system on anything over two floors (excluding a 2.5 floor mezzanine). Unless I have been misinformed, some how this home got through the requirements. Here is the catch, the builder is also the developer of this and other high priced communities. hhhmmmmmmmmm
Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
ahhh.......didn't a previous QOD bring attention to those type of light bulbs being used in recess cans as being.....well....not a good thing..
Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
I have seen potential fires start from a 100 W lightbulb in a recess can, the design of most reflector bulbs for recess cans divert the heat enough to not be a problem....the can's I install clearly say the type of bulb that goes in them and normal incand. bulbs I don't believe are listed.
I know you prefer the SunStar cans, and they are only for R or BR lamps. They're an oddity. |
The most popular Halo cans are the H7 series, and they can take a regular lamp: http://www.cooperlighting.com/specfi...opdf/H7ICT.pdf
The most popular Progress cans are the P87 series, and they can take a regular lamp up to and including 100 watt. Just noticed that: http://www.progresslighting.com/pdfs/P87.pdf http://www.progresslighting.com/pdfs/P8075.pdf Just some stuff for starters. |
Marc..as much a wattage issue as I have seen standard Incand. bulbs heat up so much around the edge of the can it discolors the ceiling from the heat...not enough to blow the thermal in some cases but enough to heat up the trim and edge sides.....causing discoloration on the sheetrock.
I dont always use Sunstar...just like the speedycans they have....installed about 130 on a large job just recently and all worked like a charm. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year Last edited by pabernathy; 6/17/07 at 2:40 AM.. |
• Socket can be used as a temporary work light with ‘A’ lamp I do notice the Halo do allow A-19 but in limited use on some models only.....as well as they restrict it to 60W bulbs...probably a wise thing. My problem is when I see them with "A" type bulbs they are usually over 75 Watts.....and that bothers me as I notice progressive is not so OPEN about the use of an " A " type as Halo is....but again notice some models do not allow "A" type from the PDF you posted....so it really depends on the model......but overlamping is a huge concern with those bulbs which is why the higher wattage ones are R or BR style bulbs. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year Last edited by pabernathy; 6/17/07 at 2:39 AM.. |
| Attic fan in garage ceiling | cowen | Exterior Inspections | 10 | 8/20/11 6:53 AM |
| Garage ceiling & door header | Al Barb | Interior Inspections | 7 | 3/27/07 1:07 PM |
| Vaulted Ceiling Insulation | rcooke | Canadian Inspectors | 3 | 1/22/07 11:24 AM |
| Recessed lighting | jfunderburk | Electrical Inspections | 4 | 11/24/06 10:47 PM |
| Recessed lighting | jfunderburk | Electrical Inspections | 5 | 2/2/06 9:27 AM |
