I have a question.
If my house is wired with an old two wire system, what can I do, without re-wiring, to protect the circuits. |
This is another one of those (I already know the answer) questions isn't it? Anyway, I'll play along.
The circuits are likely already protected by either a fuse or breaker system. You probably mean to protect people or equipment plugged into the electrical system but that's not what you asked. |
I do mean to protect people or equipment plugged into it. |
Not sure what you mean by "protect the circuits" but you could keep them all 2 prong unless you need GFCI protection then install it...GFCI's don't use the ground to work but they'll fool some testers 'cause most testers use the grounding conductor.
How about a boot legged ground, do you think that will fool a tester?
My tester picks up bootleg (false) grounds. . .
To protect people from electricution - GFCI
To protect people from fire - AFCI To protect the equipment - run a separate ground wire To protect the wires from overload - fuses or breakers To protect the wires from mice - metal conduit |
Install a three prong on the outlet in question and if possible run a green ground wire to the panel and ground it there, or I believe you are permitted to run the ground wire to a grounded incoming water line (metal). Alternatively you can replace the receptacle with a GFCI outlet, even though there is still no ground it is the next best thing if you can't run a ground.
I am not sure I understand the concept of posting questions if you already know the answer....hmmm....Guess I have been teaching college kids to long but they dont ask questions unless they really dont know the answer.
Takes up valuable time answering questions that a person already knows the answer to....in my opinion. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
[quote=pabernathy]I am not sure I understand the concept of posting questions if you already know the answer....hmmm....Guess I have been teaching college kids to long but they dont ask questions unless they really dont know the answer.
I guess you miss being the teacher, deal with it!!! this question was asked me, amd one of the ways I told the person to get answers, was to go on the NACHI board. |
I would take the SAME chill pill you asked me to take Tyrone......I was refering to the response from another that questioned the question.....
No I dont miss being the teacher.....was to many anyway....But I think it must be a Canadian thing...oh well. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
P.S....Oh..dont worry...I wont attempt to teach ya anything again...
I attached some information from the public domain: Last edited by jtedesco1; 3/4/06 at 9:28 PM.. |
Joe, you da man! Thanks!!!
Also think about adding a GFCI to the first receptacle in the stream or in the panel for added protection as well.
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 1:35 PM |
| Best Truss Repair Ever!!! | srowe | Exterior Inspections | 2 | 10/24/06 10:05 PM |
