I have verbiage for ( older 2 wire homes) that recommends that
they consult a licensed electrician for upgrading their 2 prong outlets to a GFCI type outlet.... Question.... After a 2 prong outlet is upgraded to a GFCI by a licensed electrician. Will that outlet still test open ground? David |
| Need a home inspection in New Jersey? Check out InterNACHI's listing of New Jersey certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Yes it should be labeled as such.
Just to confirm....My meter when inserted would read: correct wiring?
Is an EGC present which would allow the installation of a 3 prong receptacle or this a 2 wire cable without an EGC?
Your tester would still show open ground if the cable and enclosure is ungrounded. |
Robert is correct.
Now here is one for you Boys The other day ( 2 wire system was showing 2 greens on my tester However one green was slightly on . This is not a cheap 10.00 tester.I found the the ground screw had been turned down to scrub the Metal Box. Still not a grounded circuit . I was wondering if one of those cheap tester would have tested ok.
| GFCI won't trip by tester | rstufflebeem | Electrical Inspections | 22 | 3/22/08 8:10 PM |
| Bathroom outlet near floor: GFCI | mthomas2 | Electrical Inspections | 3 | 4/13/07 10:35 PM |
| NACHI Training Materials | jtedesco1 | Inspection Education & Training | 31 | 6/22/06 10:02 AM |
| GFCI Question | gporter | Electrical Inspections | 13 | 2/6/06 9:21 PM |
