Old 6/18/06, 7:12 PM
Default Replacing 2-prong outlets with GFCI outlets
I know this has been discussed many times but I can't get the search engine to work for me...
Can anyone give me a link to a good massage board discussion on replacing 2-prong outlets with GFCI outlets?
Thanks,
Kent
Old 6/18/06, 7:28 PM
Michael Larson's Avatar
Default Re: Replacing 2-prong outlets with GFCI outlets
Try this.
Old 6/18/06, 7:31 PM
whandley's Avatar
whandley whandley is offline
Please Note: whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Try this one...
http://www.cpsc.gov/CPSCPUB/PUBS/524.html
Old 6/18/06, 7:40 PM
Here is a recent thread on the issue.
http://www.nachi.org/forum/f19/need-help-new-service-old-wiring-5111/index2.html
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 6/18/06, 7:41 PM
I'm hoping to find a discussion on how well it actually works, since there's no grounding conductor and the GFCI is often only grounded (if at all) to the ungrounded box in which it's mounted.
Also, in this situation, does the upstream GFCI protect outlets downstream if the downstream outlets have been changed out to 3-prong and grounded to their (ungrounded) boxes?
Old 6/19/06, 12:14 AM
Bruce A. King's Avatar
If wired correctly no ground is needed, the GFCI circuitry only compares the hot and neutral current and trips when necessary. The lost current is assumed to travel to ground through a person but it can travel via wet extension cords or chaffed wires too.
There was some discussion before on here about a new type of GFCI that will require a ground connection to operate.
A connection to a metal box often is not a proper ground when the panel only has 2 wire cables and no metal conduit present.
Old 6/23/06, 7:14 PM
Paul W. Abernathy's Avatar
http://www.nachi.org/forum/f19/2-prong-outlets-narrative-examples-5562/
Paul W. Abernathy,CMI,CPI,CME
Old 6/24/06, 7:58 AM
David P. Valley's Avatar
Attachment 4278
click to enlarge
Two Prong Outlets jallingham Electrical Inspections 22 6/27/07 3:07 AM
Properly Testing GFCI Outlets tchristopher Electrical Inspections 17 3/17/07 12:19 PM
GFCI Outlets w/ No Test Button - Dont Work! HELP PLEASE! LiveAd Electrical Inspections 4 6/20/06 11:47 AM
opinions on GFCI outlets for non grounded oputlets jmerritt1 Electrical Inspections 23 5/11/06 8:22 PM
Two prong outlets and GFCI's crichiii Electrical Inspections 8 3/15/06 11:41 PM
