Richard Seay is a non-member guest and is in no way affiliated with InterNACHI or its members.
How are you reporting aluminum wiring in a residential home. I found aluminum wiring in this house. All accessible outlets had approved fixtures for aluminum wiring. I have attached a photo of panel box.
"Aluminum wiring noted at the general 120 volt connections, aluminum connections should be checked by a licesned electrician."
Timothy Hejnicki All-Specs Property Inspections (707) 428-3544 |
Aluminum service cable and larger branch circuits (#8 and larger) like the one in the pic are NOT the same issue as smaller (#10 and smaller). They are perfectly safe AND legal, IF done properly.
I see copper at the 120v branch circuits. The pic of the oxidized breaker terminal is due to no anti-oxidant being used. While not code required anti-ox is a necessary step in preventing connections from going bad. This is the only issue I see here. |
Stranded aluminum conductors are being used today, solid aluminum conductors should be called out and inspected by an electrician.
| Aluminum Wiring | jhagarty | Electrical Inspections | 23 | 10/5/07 3:56 AM |
| Aluminum Wiring | acox | Electrical Inspections | 4 | 8/27/07 12:24 AM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 1:35 PM |
| Aluminum Wiring | homeowner001 | Electrical Inspections | 36 | 7/7/06 2:08 AM |
