Old 9/28/07, 12:12 PM
David C. Macy's Avatar
Default Reporting on electrical issues
I wanted to ask other inspectors opinions on reporting on electrical issues.
Just recently I had 2 homes with numerous electrical issues.
Example. FPE main, old 60 amp fuse sub with over fusing. Attic wiring was a mess & I could only get to 1/2 of the attic. Older exterior mast, 60 amp meter base & frayed insulation at the SEC. No GFCI, K&T, open ground, reverse polarity & more.
My client received 2 estimates & the price varied from $1600 to $4200.
According to the realtor & my client the electricians went exactly by my report. One of the electricians went back as he did not estimate the exterior. The realtor & client were confused on such a large discrepancy on the estimates.
So my question is how specific are you on your report?
Old 9/28/07, 1:07 PM
Default Re: Reporting on electrical issues
You really have to look at the scope of work to figure out how they got to the number. The 1600 guy is probably just fixing the listed problems where the 4200 guy is actually doing some additional upgrades.
... or he is just making a lot more money on the job
Old 9/28/07, 1:12 PM
Roy D. Cooke, Sr's Avatar
If it is bad you can be sure you will not get it all so I CYA .
( Many many concerns, recommend a complete Electrical upgrade by qualified person.)
....... Cookie
Old 9/28/07, 1:15 PM
My client actual sent me the estimate from the electrician that quoted the 4200. There was a discrepency on updating the exterior meter & mast.
The reator was trying to blow off some off the work so his deal would go thru.
I was impressed by my clients persistence to have the estimate done properly by the electrician.
Actually this is a quote from the electrician.
The electrical is a handymans nest of trouble & must be addressed, were lucky it didnt burn down already.
Old 9/28/07, 1:21 PM
mnahrgang's Avatar
How detailed I am, depends on what I find. For example if the only problem is a single reverse polarity outlet, I'm very specific as to it's location, define it as a minor defect and reccomend that it be repaired. And it would be acceptable for an electrician to use my comment as an estimate for that.
On the other hand, if I find numerous issues as you did, I would call it out - more or less as your paragraph above is written. It would be a list of issues (and limitations), with a recommendation for an electrician to fully evaluate and give an estimate of repair costs. I would even include an comment on the lines of "Because of the extent and volume of the defects found, it is conceivable that there are other latent defects not apparent in a non-invasive visual examination. Therefore I reccomend that the entire electrical system be re-evaluated by a qualified electrical contractor for full repair recommendation and estimate of repair costs." BTW if the electrician is using my report to do the estimate, I wouldn't give them the time of day. They need to LOOK at the system and do the estimate on their own.
If it's a single issue, I call it as being wrong and reccomend repair. If it's more of a "system" issue, as you have described, I call it out for a specialist to look at it.
As an analogy, your General Practitioner can tell you that you need a tetanus shot. He shouldn't tell you, that you need a heart transplant. If he suspects that, he should send you to a cardiologist for his evaluation. Neither should he be telling the cardiologist how to do that transplant.
Mark Nahrgang
www.HeyMark.info
Old 9/28/07, 2:52 PM
I suppose there are plenty of electricians looking for work so they could be loading up these proposals
Old 9/28/07, 4:29 PM
I would absolutely stay away from making a definitive list of recommendations - unless you are a licensed electrician or P.E. and are making recommendations in that capacity. You are sure to miss some things in such a mess and would not want the buyer coming back to you to ask why.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 9/28/07, 4:37 PM
I agree completely.
I am a retired Electrician but still try and use the Kiss method.
It also saves time when there are just too many concerns to try and cover.
........ Cookie
Old 9/28/07, 4:40 PM
tdietrich1's Avatar
three estimates are usually the minum I recommend. Also, if the electrician is just working off the report without 'further evaluating' the situation, I would scrap his arse.
imho,
tom
Old 9/28/07, 5:21 PM
Unmoderated Guest
This is actually not a very fair stance. MOST sellers are simply looking to sell their house. When a HI comes in and writes up half the house the seller will logically only do what is asked.
I'm actually not sure when this whole business started that someone who sells a house is REQUIRED to make every repair and upgrade. And yes guys, folks think that if it is in your report it IS required. That's just a real world fact.
If a seller gets a report and hires me to fix any "issues", it is only logical that I am asked to do just what is in the report. If that report states to check every wire in the house then I'll do that. Just don't expect me to do that voluntarily and for free.
Old 9/28/07, 5:58 PM
I agree with what Speedy has posted.
I spoke with the sales manager of the electric company that did the estimate and asked him about our inspection reports.
He knows are roles as generalist and does not expect us to find every single violation. (Codes, AHJ)
My past reports were very vague and I specifically try to detail the issues so that the realtors, clients & electricians understand the issues.
Old 9/28/07, 5:59 PM
Doug Edwards,  CMI's Avatar
Had an occasion to do an inspection on an old farm house in a very remote / rural community. The electrical system in the house had been added on so many times and by someone who did not know their butt from apple butter about electrical wiring. It was a nightmare and a death trap. The list of electrical discrepancies were about 3 pages long. I did get detailed but I felt in this case it was very well appropriate to recommend a full electrical evaluation by a licensed "lectrician" as they say here. There were too many areas of concern that were not accessible and too many glaring life threatening errors, there was just no telling what was lurking within walls and cavities. The listing agent had a conniption fit and called me to ream me out ( to no avail). Her comments were, "That is going to raise so many red flags." To which I told her "I sure hope so!" The buyer was a young woman with a quiver full of small kids and bless her heart appeared to perhaps be brain dead. Nice girl but completely clueless on any subject and dangerously close to being in a coma. She was a prime candidate for being taking for a "Trip to Abilene". I guess what I am trying to say is; do what you have to, to convey to your customer what the problems in the house are. Something as "minor" as a Reversed Polarity could actually kill someone. Plug a lamp into an outlet with Rev. Pol and if they touch the metal socket while turning it on they could be electrocuted. Suddenly it "aint" so minor no more.
- John Stuart Mill
Old 9/28/07, 6:14 PM
I write the report of what I see and find.
It is not my decesion whether they buy the home or not .
It is not my decesion if the seller or the purchaser does or does not fix the concerns.
.I do not know if the person who is buying the home intends to strip it and do a complete fix push it over or just fix the problems.
If they use it as a bargaining tool or not .It has no bearing on my report.
....... Cookie
Write hard talk soft miss nothing.
Old 9/28/07, 6:23 PM
Exactly! Couldn't tell you if she ended up buying that house. Don't care, I don't have a dog in that fight. But, they can never come back to me and say I did not warn them of the dangers.
- John Stuart Mill
Old 9/28/07, 6:42 PM
Marc D. Shunk's Avatar
Banned
I fully understand why there was such a price discrepancy. When an electrician is presented with the electrical portion of a home inspector's report, it is generally accompanied with oral instructions from the present or future homeowner. These oral instructions may limit the work to the items on the list only, or may be more general like "look the place over, and don't forget the things on this list". Every electrician that was bidding the work may not have gotten the same set of accompanying oral instructions. Some electricians (like me) bid work like this twice. One copy will be just what you asked to have done. Another copy will include the work that could be done to bring the whole place up to modern standards. Some electricians automaticly bid work like this to a higher standard than was originally asked for. This is a perfectly valid business model for those guys, but I suspect it prices them out of a lot of work.
Download the videos here all about physics and electricity jtedesco1 Electrical Inspections 5 9/14/08 4:58 PM
Handbook for Electrical Safety pabernathy Electrical Inspections 1 1/1/07 2:14 PM
Chicagoland Electrical Code Ordinance jtedesco1 Electrical Inspections 0 6/16/06 3:10 PM
Electrical Safety Information jtedesco1 Electrical Inspections 0 2/19/06 2:48 AM
