Can I detect plastic water pipes by checking the resistance of the piping?
If so where and how would I do this? |
I'm a little confused about what you're asking. Are you asking:
Ahh...
Are you saying....how do I determine if I see metal water piping going into the wall.....that they did not change over to plastic somewhere and IF it is all a complete run of metal water pipe....is that what you are asking? Paul W. Abernathy |
Any break in the metallic piping will give you the same indication as if it were plastic.
What you are asking, would not be a reliable way to determine the type of piping in the home. At best, you could check the bond (or lack of bond) at the metallic piping. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
If you have the grounding pigtail adapter for your Suretest you could verify the grounding path that way. Just be sure nobody is touching the plumbing when you do.
I'm curious, what is the point?
This is what is swishing around in my snow globe of a brain today: The NEC, I know this isn't a code forum, says use the water pipe. Then says if you use the water pipe drive a rod(or a plate, or use rerod, etc). The only time you 'measure' anything is when you are checking the grounding path for rods. It is assumed that the water pipe is acceptable if metal(10feet) and grounded to. So the only 'resistance check' you need to do is maybe pull on accessible ground clamps. Although I think this isn't SOP either. tom |
I think he was just trying to figure out a way to determine if the whole piping system was metal or plastic...so to be aware of IF he should bring up any additional bonding issues.
Paul W. Abernathy |
It was a two part question the first part being yes or no, the second part was where I had hoped to spark some theroectical discussion.
I guess I'll play around with my fluke meter and get back to you. |
Brian you are nut's. Love Todd I would give you a greenie, but allas I am not allowed. I am up to 158 points though. LOL I have to go to Scotts dale some time next month to meet with a Builder. Is ok if I call you ahead of time so we can meet for lunch? If so e mail me, or post it here. |
Kevin Kevin M. Kenny, Sr. Kenny Home Inspections Oak Forest, Illinois 60452 Nachi #6070990 http://kennyhomeinspections.com
Any conductivity in water is due to disolved minerals or other chemicals. |
The answer is yes! I do it all the time. I am not an electrician. I am not a plumber.
Go to a bathroom outlet. Turn on your multimeter. Put the black lead from your multimeter into the small (hot) slot in the outlet. Take your red or other lead and put it on the water shut off stub out at the wall. If you read 122, 124, 126 or around there, it's 99% sure that it's metal. (cu, galv. etc.) If it reads 35 - 70 or around there, it's plastic. (pex, PB, pvc, etc.) I have been doing this for 3 years. I started doing it in houses that I already new what type of pipe it had and the test confirmed it. Then I did the test in houses that I didn't know the type of pipe, but kept the results in my head, and later confirmed the type up in the attic. Just try it on a pex house. You will get a low reading. On a old copper or galv. house you will get the high reading. "Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. Last edited by mtimpani; 3/31/07 at 10:14 AM.. |
Are you sure you have described this correctly? |
