During a recent inspection, my electrical tests revealed several electriical outlets with revese polarity. How serious is this and what kind of problems could ths cause?
David, I always report this as an Issue with the electrical system and recommend a licensed electrician properly rewire these outlet(s). Under certain circumstances it could present a shock hazard, so it could be very serious !
William
Thanks for the info- I'll pass it along David |
Thought I would add this;
Hot / Neutral reversal, called reverse polarity, is probably the most common error you're going to encounter. While few (if any) electrical devices care much whether the current runs left to right or right to left, almost every electrical plug made in the past few decades is polarized for safety's sake. They can only be plugged into (modern) outlets in one orientation, which is designed to ensure that if there are any electrical shorts in the device, exposed metal parts don't carry the current. Wall sockets that have reversed polarity are considered an electrical shock hazard, which is why they're noted on pre-purchase house inspections. Fortunately, the condition's fairly easy to fix: all you have to do is reverse the black and white wires. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
gmortensen is a non-member guest and is in no way affiliated with InterNACHI or its members.
Think of a simple lamp. Instead of the button at the bottom of the socket being live the metal sides are live.
Wild Leg is a non-member guest and is in no way affiliated with InterNACHI or its members.
A modern gas furnace will not function with reverse polarity. I haven't seen anything else that cares, but I am sure there are some other appliances. Regardless, it is still a hazard and should be repaired.
Most lap-top/notebook...have polarity protection but may blow an internal fuse when used on a reversed polarity receptacle
BEST to check the receptacle before plugging in your equipment on-site...you never know... ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Didn't think this was an issue since it goes through a transformer first anyway. |
| Reverse Osmosis | phinsperger | Plumbing Inspections | 3 | 10/30/07 7:28 PM |
| reverse polarity?? | Scott Schultz | Electrical Inspections | 33 | 10/24/07 2:50 PM |
| Reverse Polarity | dscott2 | Electrical Inspections | 12 | 6/26/07 1:22 AM |
| Garage Door Safety...No Reverse...Advice Please | gliebig | Exterior Inspections | 33 | 3/17/07 8:28 PM |
