| Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera. |
How do you guys test for reverse polarity in a house with two hole outlets?
Cut the ground pin off your tester? |
With a non-contact voltage probe. Some people call it a "tic tracer". The wider slot is neutral, and the narrower slot should be the hot. The ticker should only light up in the shorter slot. I know some guys simply use one of those 3-prong to 2-prong adaptors on their regular receptacle tester.
If you run across any old receptacles where both slots are the same height, or where both slots are "T" shaped, I would recommend you call them out as recognized hazards. Put no special effort into determining the polarity of receptacles of this type. |
Justin D. Schlueter is a non-member guest and is in no way affiliated with InterNACHI or its members.
![]() One of the reasons that I think that they are scary is that they could be wired for 120 or 240 volts. In other words, you could have one of these receptacles wired to 240 volt circuit. (and be able to plug in 120 volt appliances) |
good point
With a 2-prong adaptor, these little testers tell you if there is power, but don't tell you polarity if there's no ground. OK for testing old razor outlets, there is no polarity concern with those, isolation transformer. The old outlets like the one in the middle are not polarized and ought to be replaced.
John Kogel www.allsafehome.ca Last edited by jkogel; 8/6/08 at 12:53 AM.. |
Attached is a few pics of receptacles/plugs.
Thanks gents.
As was stated already, the 3 prong testers do not work without a ground connection. You need to use one of these (or equivalent) to test for reverse polarity on all open ground 3-prong receptacles and all 2-prong receptacles. I like the fluke model, however I have not tried the new/current version that fluke is selling.
"An expert is a person who has made all the mistakes that can be made in a very narrow field" Niels Bohr "Learn all you can from the mistakes of others. You won't have time to make them all yourself" Alfred Sheinwold Eureka, Fortuna & Arcata, CA
I just use my hand as the electrode by holding a probe tester with one probe on my hand and sticking the other probe in the slot. The hot slot will cause it to light up just a little bit -- barely noticably, but visibly.
Sometimes I shake my hand as if shocked as a practical joke ... sometimes making a "home inspector jackass" joke. |
Probe tester. I don't even so much as get a shock, but it is sometimes difficult to see the indicator light up.
But I'll test that 2-prong adaper idea. Never occurred to me that would work. As I thought, it doesn't work: just shows as an open ground either correctly or incorrectly polarized. Last edited by fbartlo; 8/8/08 at 1:17 AM.. |
double post
Chuck Evans (TREC #7657) HomeCert Houston Home & Thermal Inspections Houston Infrared Thermography and Thermal Imaging Inspections Houston Home Inspector Houston, TX Last edited by cevans; 6/2/09 at 11:59 PM.. |
| Reverse polarity | ddunning | Electrical | 9 | 5/9/08 11:08 PM |
| reverse polarity?? | Scott Schultz | Electrical | 33 | 10/24/07 2:50 PM |
| Reverse Polarity | dscott2 | Electrical | 12 | 6/26/07 1:22 AM |
