ghawley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Today, I came upon a ceiling fan installed in an apartment with a concrete ceiling and cement block walls. The wiring was run on the ceiling and walls and covered with wood molding down to the vicinity of the receptacle. At the end of this molding run the Romex ran outside the molding about a foot or so and was connected to a male 3-prong plug that was plugged into that receptacle.
I didn't tag it because I couldn't really determine if it was a problem. Wood moldings are OK to use in our area, so that was not a problem. The male plug was connected properly, so that was not a problem. It was just weird to see Romex with a 3-prong plug. I searched the NEC reference books that I have and found nothing that prohibits Romex from having a plug attached or from being used as an "extension" cord for that matter. Am I missing something? Thanks for any responses. |
Gary,
I remember reading somewhere (I looked but can't find the source right now) where you can't use solid conductors as an extension cord. They are more prone to breaking than stranded conductors. But that would assume that one would be coiling and uncoiling the cord. The only reference I could find was in my Code Check chart which referred back to IRC 3303.3 which is Listing and Labeling of electrical system components being used in such a manner that is consistent with manufacturers installation instructions. My gut feeling is that NM is not listed to be used in a cord and plug manner. There is also a reference in IRC 3809.1 where is discussed flexible cords being used in leiu of permanent wiring. Given that a ceiling fan is intended to be a "permanent" fixture it should therefore be supplied by permanent wiring. |
Hi to all,
Gary, am I understanding you correctly? from what you are saying the outlet was fed by a male plug attached to romex, is that correct? If so then the plug prongs would be energized all the time, and would present a clear shock hazard should someone remove the plug. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Gerry,
I think he is saying just the opposite. When you insert the plug (connected to Romex) into the receptacle, it energizes the Romex run to the ceiling fan. In other words the Romex has been converted into an extension core with a ceiling fan on one end and a plug on the other end. Jason Sieg, CMI Davison, MI NACHI05091399 Knowing the current condition, to make a wise decision.
President, Great Lakes-East Chapter Join NACHI Great Lakes - East Chapter http://mi.nachi.org/greatlakes-east/about.html ssieg@gfn.org |
Romex wire is not approved as a flexible cord. [IRC 4001.3]
Romex wire is not authorized for use outside of the finished wall system Unless it is protected within an approved conduit. |
Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
The rule actually says "protected from physical damage" not "conduit". A wood chase might be OK but the cord cap (plug) is still troubling.
lcapaul is a non-member guest and is in no way affiliated with InterNACHI or its members.
Ah the good old "Mexican service drop". That is not as uncommon as one would think. OTOH if this "drop" was a messenger supported UF cable, properly terminated and high enough it might be legal.
Thank you everybody for the responses. My gut feel is that is wasn't right, but I just wasn't certain of the exact reference. I am completing the report this morning with everyone's comments in mind.
The suggestion to bring this into compliance woiuld be a surface extension box with the splice in there. They would still be able to have the receptacle on the extension. A plastic wiremold box would work.
whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
That's not always the case David. In several counties here in california romex maybe left exposed when installed inside the open wall studs or above the plate line. I agree however in most areas romex subject to physical damage must be protected. |
wward is a non-member guest and is in no way affiliated with InterNACHI or its members.
If the fan has the plug with romex it's ok
you can unplug the romex and all is well. I find this on lanis with fans pluged into the receptracle. If you can un plug it than it's no more than an extention cord. |
Did a draw inspection, today. Went down in the basement and there was a radio going (with Polish music). I wasn't looking closely and I tripped over am electrical cord (to the radio) and the radio died.
I appologized and looked down. The radio power wire had no plug. Just the bear wires stuck in a multiple recepacle extension cord. The worker came over and pushed the wires back in. No harm, no foul. Guess what kind of workers they were? Yep. Licensed and insured, union electricians. Go figure. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Whitley,romex is an indoor jacketed wire, that is not to be run outdoors on lanais. Aside from that the last thing i would want to unplug here in florida is an extension cord run by a homeowner !!
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| Romex question | jcahill | Electrical Inspections | 22 | 7/11/07 8:26 AM |
| Romex Wire Through Stucco Wall | Tab M. Wilcox | Electrical Inspections | 12 | 5/11/06 1:33 AM |
| Romex wire connected to standard male plug. | ghawley | Electrical Inspections | 2 | 3/2/06 1:35 PM |
| Romex on a Boiler? | mgifford | Electrical Inspections | 7 | 1/10/06 4:27 PM |
