Old 10/4/11, 7:20 AM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Romex in the garage...need advice
Does romex always have to be enclosed in conduit or behind
the wall below 7ft. in a residential garage?
This romex starts about 3ft. high.
An Ounce of prevention is better
than a pound of cure :}
Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/4/11, 8:09 AM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: Romex in the garage...need advice
There is no minimum height mentioned in the NEC. However, there is a prohibition against using NM where subject to physical damage. Physical damage is not defined in the NEC and is subject to individual definition. Acceptable methods of protection are listed in Article 334.
Side note, raceways are prohibited from providing support like is shown with the NM ty-rapped to the conduit.
Old 10/4/11, 8:25 AM
Gary D. Rowden Gary D. Rowden is offline
Anytime I see exposed romex wiring in a garage that is lower than 7’ I call it out, even though when structure was constructed it may have passed inspection.
“There is exposed romex wiring inside garage that is low enough to be subject to physical damage and could cause a danger, this is a safety concern. Recommend further review and corrections from a qualified electrician contractor.”
Old 10/4/11, 9:11 AM
thanks for this verbiage....
David
Old 10/4/11, 9:12 AM
Thanks for the feedback...
David
Old 10/4/11, 10:57 PM
David - Use your head / FORGET when it was built or NOT built.
PART was in conduit / part was outside conduit in same location ... This is NOT rocket science. Its handyman crap. Write it needs repair...Period.
Old 10/4/11, 10:59 PM
Paul Pendley Paul Pendley is offline
Lets not forget the black taped extension cord from the outlet!!
Paul Pendley
Premier Property Inspections
866-458-8516
Old 10/5/11, 4:22 PM
Pete Campbell's Avatar
Pete Campbell Pete Campbell is offline
always in the wall or in conduit under 7' A.F.F.
Pete Campbell
pete4545@comcast.net
http://www.PortStLucieInspections.com
http://www.ChooseGI.com
http://ifwemissitwewillfixit.com
Inspecting Fort Pierce, St. Lucie Village, Lakewood Park, Vero Beach, Indian River Shores, Sebastian, Fellsmere, Fort Drum, Okeechobee, Jensen Beach, Stuart, Palm City, Hobe Sound and Indiantown, Florida.
Old 10/5/11, 5:52 PM
Eric C. Van De Ven's Avatar
Eric C. Van De Ven Eric C. Van De Ven is online now
Must be protected. for those of you afraid of the code, it is a safety issue.
Guy finishes trimming his trees with one of those pole saws and lays it down on the Romex.....
Ask me how I know!
Old 10/5/11, 9:26 PM
Robert Meier's Avatar
Where does the 7' come from?
Old 10/5/11, 11:14 PM
Unmoderated Guest
Not according to the NEC.
There is a possibility that the conduit was not needed in the first place. While it should not have been secured to the conduit, NM can be run on the surface. Again the subject to damage is subjective.
Old 10/6/11, 12:01 AM
Bruce A. King's Avatar
Does everyone get on their knees and look under garage steps?
I found some wiring completely eaten through under a one foot tall landing with bare copper up against the wood. This was the only romex visible in the entire garage.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Attached Garage Fire Containment. Please proof this new inspection article. gromicko General Inspection Discussion 38 8/12/09 6:55 PM
Garage door inspection procedure bgromicko General Inspection Discussion 5 8/7/09 12:47 PM
Garage / Apt separation Carol Jones Structural Inspections 1 6/14/09 7:56 AM
