Roof Top AC Units
Tell me if you see any defects on this roof top? I have some electrical items, but feel sure that there may be others, such as a flat roof! I get chills thinking about standing there in a wind storm. Last edited by jtedesco1; 3/4/06 at 9:28 PM.. |
Bob Badger is a non-member guest and is in no way affiliated with InterNACHI or its members.
No one is trying?
OK the bottom right unit has the wrong size fuse and the top left one has a skinned conductor. |
Top right unit is a bit crooked. . .
Joe;
You expect us to see that from the picture? Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
The two BBQ grills are much too small to serve a facility of this size.
The condensing unit photo is too condensed
Not only does the top right unit look crooked, but it looks like there were originally 4 units in the lower row. Do you suppose one of them blew off the roof?
I guess that's what they get for not installing a hand rail. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
It's hard to tell much from the pic. But I would think those units should be sitting on something a bit more stable than a couple of 4x4's. Obviously they're not very secure from the looks of the one on the upper right.
Rick Slocum NACHI # 04072697 Elizabeth CO 80107 ABSOLUTE Home Inspection Service |
I should have asked "what do you look for here?"
1. Fuses or Circuit Breakers "HACR" or just a plain nonfused switch? 2. Thermostat wire not in same line with AC electric supply wires 3. Receptacle within 25 feet on GFCI and with a bubble cover 4. Proper equipment grounding 5. ? I am still afraid of the wind here! Last edited by jtedesco1; 3/4/06 at 9:28 PM.. |
| A little on the Commercial side of things. | mcyr | General Inspection Discussion | 457 | 8/1/09 11:50 AM |
| Cracked shingles | pwigle | Exterior Inspections | 54 | 4/24/09 12:52 AM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 1:21 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 2:19 AM |
