Old 9/26/06, 9:04 AM
horkyroj horkyroj is offline
Please Note: horkyroj is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Running Romex Down I-Beam???
I am staring to layout a plan for finishing out my basement and trying to figure out the easiest and safest way to run electrical down the length of my house. The current holes in the floor joists are packed with romex for the rest of the house so my options are to either drill another set of holes or since I am going to frame the I-Beam in I was thinking perhaps I could run the romex down the I-Beam. I was thinking of using some sort of clips or U-Brackets to secure the wires. Any thoughts on this method? If figure its safe and I would not have to drill anymore holes through my floor joists. I figured I would ask here before I call the city inspector to get his put.
Thanks all,
Old 9/26/06, 11:56 AM
Default Re: Running Romex Down I-Beam???
At one time the NEC included an Article 357 covering "Structural Raceways" and would have permitted the installation you describe. Ask the Inspector if you can use the structural member, even though no longer in the Code.
Someone here in this audience may have the time to research for the article I mentioned.
PS: Why come here to ask this question? You may be surprised by the advice received from one of the DIY forums, seems that there are many knowledgeable people who have all of the answers you are looking for, even though not affiliated with the trade?
Old 9/26/06, 12:13 PM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
Horkyroj-
You are always welcome here to ask any question you might have.
http://www.SmithHomeInspection.com
SmithHomeInspection@yahoo.com
NY State Lic. # 16000008304
631-434-5200
Old 9/26/06, 1:52 PM
Caddy makes beam clips. I can't think of any reason why you couldn't use a beam clip in conjunction with "stackers" or some other supporting method.
You could use the plastic cable rings with the double back sticky tape if you wanted to.
Just keep them 1.25" away from the nailing surfaces of the framing you are attaching your wall finish to.
Old 9/26/06, 1:59 PM
Robert J. OConnor's Avatar
For new work the specifics really depend on your local codes, and more importantly how the local building officials interpret/apply those code provisions.
It sounds like a good option to discuss with the inspector/electrician would be to attach a vertical 1x or 2x piece of lumber to the vertical web of the I-Beam (called a "packed" beam), and then attach your cables to that. Keep in mind you can not have any concealed electrical connections like splice boxes once the work is completed, and everything needs to be inspected by the local building official before you cover the wiring.
JMO & Your local mileage may vary ...
</IMG>
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Steel beam lateral support Mark Ellison Structural Inspections 10 1/16/07 11:40 PM
Romex Wire Through Stucco Wall Tab M. Wilcox Electrical Inspections 12 5/11/06 2:33 AM
Romex wire connected to standard male plug. ghawley Electrical Inspections 2 3/2/06 2:35 PM
Romex on a Boiler? mgifford Electrical Inspections 7 1/10/06 5:27 PM
