The inside of panel is not affected with any moisture. Would you still call this out because of the outside rust?
Attachment 17940 Thanks "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com Last edited by nbhi; 7/8/08 at 8:42 AM.. |
Hi to all,
Gary I would note it as a concern, even if it was dry inside it will not remain like that for long. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Gerry
Would you recommend replacement in the near furture, or now? Thanks "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
Looks like it may not provide the minimum of 3 feet of working space in front of it as well?
Joe
Where is that written at, the 3 feet, I was looking for that very item. Thanks "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
Some would say that as the rust isn't UL listed it has to go!! Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
| Rust and heat exchangers | cbottger | Inspecting HVAC Systems | 6 | 10/26/07 7:15 AM |
| Oozing Rust at Breakers | srowe | Electrical Inspections | 10 | 5/4/07 5:06 AM |
| Rust in panel box | sfalvey | Electrical Inspections | 10 | 4/10/07 7:35 PM |
| Rusting Water Heater | Skip Erwin | Plumbing Inspections | 9 | 11/23/06 3:50 PM |
