Old 8/19/09, 9:15 PM
Tom Yeager Tom Yeager is offline
Default Sanity Check
Just to be sure, before I call it a defect, there is no way the neutrals and grounds really are separate on this Sub Panel, correct?
Tom Yeager
Owner/Certified Inspector
Inspect-It 1st
303-464-9090
www.tyeagerinspects.com
NEHA Radon Certification # 104169 RT
NACHI Certified Home Inspector
Find an InterNACHI certified New Hampshire Home Inspector (and anywhere else in North America)
Old 8/19/09, 9:36 PM
mnahrgang's Avatar
Default Re: Sanity Check
Not the way they are supposed to be. They did a neat job "separating" them but they are on the same buss bar, so they are connected.
That green bonding screw at the bottom should also be removed (can't tell if it's touching the panel or not, but it shouldn't be.)
Mark Nahrgang
www.HeyMark.info
Old 8/19/09, 10:23 PM
That's what I thought, I just wanted to make sure, and yes, the green screw was attached to the panel. It was just so obvious that they were separated, even with the grounds on the screw side that it made me paranoid there was some wacky new bar out there that's insulated between the top and bottom... It's been a long week already!
BIG THANKS!!!
Tom Yeager
Inspect-It 1st
303-464-9090
Old 8/23/09, 10:15 PM
IF the feed is corrected to provide 4 conductors as it should be, the green screw would be required to bond the ground conductor to the panel.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 8/24/09, 8:11 AM
Jim Port Jim Port is offline
Unmoderated Guest
Frank,
In my experience the bond screw is only used to bond the neutral bar to the can. If it is not needed it is not used elsewhere.
Auxillary ground bars bond to the can with their mounting screws and they are much smaller.
Old 8/25/09, 9:51 AM
Richard W. Washington's Avatar
Richard W. Washington Richard W. Washington is offline
Originally Posted by Jim Port View Post
Frank,
How would you know when the bond screw would be needed to bond it to the neutral? How can you tell if it is needed or not?
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Old 8/25/09, 1:10 PM
mnahrgang's Avatar
The bus bars need to be bonded to each other and to the panel in the case of a main panel (where the shutoff is.) In all other cases (it's my understanding) the neutrals, grounds and panels are not bonded to each other.
Mark Nahrgang
www.HeyMark.info
Old 8/26/09, 9:32 AM
Great. Thanks.
Old 8/27/09, 2:03 AM
I believe that is not quite correct, Mark. In the case of a sub-panel, the ground bar is bonded to the panel through its mounting screws.
Old 8/27/09, 7:10 AM
mnahrgang's Avatar
If that were the case, then wouldn't the neutral bar also be bonded to the panel through its mounting screws, thus making a neutral/ground connection in the sub panel (which wouldn't be correct)?
Mark Nahrgang
www.HeyMark.info
Old 8/27/09, 8:27 AM
In a remote distribution panel (sub) the grounded conductors (neutrals) are isolated from the panel board and the grounding conductors (grounds). The grounding conductors (grounds) are bonded to the panel board.
Larry Kage, CMI
231 929 3525
Old 8/27/09, 8:22 PM
mnahrgang's Avatar
I'll grant you that, but not through the mounting screws. If that were the case, the mounting screws of the neutrals would also be bonded to the panel via their own mounting screws.
Mark Nahrgang
www.HeyMark.info
What's Inside A Chimney mcyr Inspecting HVAC Systems 14 9/17/08 6:11 PM
Requiring Money Order or Cash Erol Kartal General Inspection Discussion 7 7/22/08 8:48 PM
AC check list jcahill Inspecting HVAC Systems 10 7/17/08 6:33 PM
Electrical Inspection Training for Home Inspectors jtedesco1 Inspection Education & Training 6 4/27/06 10:43 PM
