Can someone tell me if this is normal for this breaker??
Thanx HHH Home Inspection Services LLC Pinellas Park, Fl. 312-371-5076 http://www.inspectorpages.com/thession http://www.pinellasinspector.com/ http://www.facebook.com/pinellashomeinspection Home, Health, Happiness |
| Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Are you referring to the 100 amp marked MAIN? A back fed breaker is required to be held in place by a screw or retention clip. I'm guessing that's why the screw is there. The question is was that breaker designed and listed to be held in place by that screw?
That looks like it might be a Cutler Hammer Type BR 100A breaker feeding that panel. They come with a special hole in the breaker for a hold-down retainer screw when used to backfeed a panel. Did it look like the attached pics?
P.S. Backfeeding means that the feeders supply power to the panel through a typical breaker position, and not a factory installed main breaker at the top (typically on a panel that doesn't have a main breaker, called an MLO panel). It's OK to do it that way, but the main breaker for the feeders in that panel needs a special hold-down retainer clip or screw from the breaker manufacturer to keep the breaker in position. Otherwise if the breaker is removed or comes out without shutting off the power from the source, the breaker will still be hot ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
Here is a photo of a CH backfed panel with the screw type main breaker hold-down.
And ya just have to ask yourself, how long did it take sparky to wire up this panel ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
One of the neatest panels I have seen ... but if you look close he didnt re-identify a white wire on one of the 2-pole breakers ...
(Forget the ground wires ... RM's right, it's twisted bare grounds) Here are two of my favorites ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... Last edited by roconnor; 7/9/11 at 9:55 PM.. |
I think the grounds are just bare color that has been twisted together. They do not look like red insulated conductors.
Also the requirement to re-mark a white as a hot may post date this installation. |
I thought that requirement has been around for a long time? Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... Last edited by roconnor; 7/9/11 at 8:31 PM.. |
Not very long. Maybe 2 or 3 code cycles.
Thanks for the confirmation and taking time to look that up Robert.
Actually I didn't look it up because I cannot find some of my electrical reference books. I will try to confirm what I was saying from memory, this one gathered a lot of complaints about sanitizing the NEC for DIYer's. |
NEC 200-7 which has the requirement for white wires to only be used for neutral (grounded) conductors unless re-identified dates back at least to 1996, the earliest NEC edition I have handy. I think it goes back a lot farther than that.
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... Last edited by roconnor; 7/9/11 at 9:13 PM.. |
I might be thinking about re-marking the white in a switch loop.
Here is essentially the same requirement in the 1959 NEC ... I dont have anything older than that in the archives.
I might have been thinking of that as well. My only question is if it has been required for so long why is it that every 20 year old or older panel never has the white re-identified when used on a two pole breaker? |
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 7 | 4/16/12 9:51 PM |
| Screw on Main Breaker...question | dnasser | Electrical Inspections | 4 | 1/27/11 2:49 PM |
| Steel post question | sspradling | Structural Inspections | 42 | 3/2/07 8:59 PM |
| Screw in Breaker | scosta | Electrical Inspections | 18 | 11/11/06 3:35 PM |
