Old 11/10/06, 7:50 PM
scosta's Avatar
scosta scosta is offline
Please Note: scosta is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Screw in Breaker
Have never seen this before, Challenger Panel
Why would there be a screw in it?
Thanks, Steve
Old 11/10/06, 7:54 PM
Default Re: Screw in Breaker
Steve,
What size is that breaker....and is it feeding a SUB panel or is THIS panel being fed by this breaker....? IE: is this the disconnection for this panel.....
Paul W. Abernathy
Old 11/10/06, 7:55 PM
Sure doesn't look right...
Larry Kage, CMI
231 929 3525
Old 11/10/06, 8:20 PM
scosta's Avatar
Paul,
Its a 100amp breaker in the Main and only panel.
Steve
Old 11/10/06, 8:21 PM
scosta's Avatar
Paul,
It is a 100amp breaker, it is the disconnect for the Main and only panel.
It is the disconnect for this panel
Steve
Old 11/10/06, 8:24 PM
Jason A. Sieg, CMI's Avatar
Jason A. Sieg, CMI Jason A. Sieg, CMI is offline
Originally Posted by pabernathy
Steve,
What Paul is doing is have you think about the use of the breaker. If it is the main or the disconnect for a sub panel it is supposed to be mounted so that it is not easily removeable. That would be a proper install under those situations.
Did I explane that correctly Paul?
Jason Sieg, CMI
Davison, MI
NACHI05091399
Knowing the current condition,
to make a wise decision.
President, Great Lakes-East Chapter
Join NACHI Great Lakes - East Chapter
http://mi.nachi.org/greatlakes-east/about.html
ssieg@gfn.org
Old 11/10/06, 8:36 PM
Thanks, Steve
Back-Fed Devices
Plug-in-type overcurrent protection or plug-in type main lug assemblies that are backfed shall be secured in place by an additional fastener that requires other than a pull to release the device from the mounting means on the panel.
Old 11/10/06, 8:51 PM
scosta's Avatar
Joe,
Backfed as in through the back of the panel?
The conductors came through the top.
Steve
Old 11/10/06, 9:04 PM
Backfed does not referr to where the conductors come into the panel.
It referrs to where the electricity comes from. Like from a generator rather than from the power company.
Jason Sieg, CMI
Davison, MI
NACHI05091399
ssieg@gfn.org
Old 11/10/06, 9:07 PM
scosta's Avatar
Its not backfed, its a power company feed.
Old 11/10/06, 9:13 PM
http://www.comitalo.com/images/panel1.JPG
The Type SE Cables here are the "service entrance conductors" and they are energized, and therefore are "back feeding" the circuit breaker through the device screws on the CB.
Old 11/10/06, 9:40 PM
From UL:
Markings on panelboards that employ plug-on units require the use of a hold-down kit when the units are back-fed and field installed supply conductors are terminated on the plug-on unit.
The marking indicates: "Back-fed _____ requires hold-down kit Cat. No._____ " or the equivalent.
An identification of the applicable back-fed unit is specified in the first blank - for example, circuit breaker, fused switch, or terminal kit; and the catalog number of the required hold-down kit is specified in the second blank.
Old 11/10/06, 10:50 PM
Unmoderated Guest
Exactly. And the circuit breaker is feeding the panel busses through the stab on's. Opposite of how a branch circuit breaker works.
This is a factory installed proper hold down screw. I've seen (and installed) my share of 'em.
Old 11/10/06, 11:49 PM
You can screw them all down if you want. It is only required if the breaker is backfed. Most commercial manufacturers make panels where all the breakers screw to the bus, no stabs or "U" clips. It certainly helps the reliability.
Old 11/11/06, 5:46 AM
jking2 jking2 is offline
If the screw goes into the bus bar, it certainly makes it easy to check for power. Just lick your finger and touch the screw!
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
Subpanel Bonding Screw away Electrical Inspections 24 1/9/08 2:46 PM
Electrical Guru Question? Breaker lock outs pdoane Electrical Inspections 4 9/7/07 2:05 PM
Double Tapped Breaker tjohnson3 Electrical Inspections 8 4/20/07 9:04 AM
Steel post question sspradling Structural Inspections 42 3/2/07 8:59 PM
