Is it a issue?
| Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Looks fine, that is required since it is a back-fed breaker that could pop out.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
I would be more concerned about over amount of insulation not cut back in the panel and the sloppy work done.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
I would be concerned with all of the cables entering in one connector or raceway in the top right corner.
What is the size of the branch conductors , on those 20 & 30 amp breakers ?
galaxyhomeinspections.com An amateur built the Ark ! Professionals built the Titanic ! |
| Half Height Breaker Question | bsmith | Electrical Inspections | 2 | 9/10/09 6:54 PM |
| Neutral bus bar failed inspection | Greg Moritz | Electrical Inspections | 18 | 1/19/08 1:53 PM |
| Arching Causes Main Breaker To Trip? | msylvester | Electrical Inspections | 10 | 10/22/07 3:57 PM |
| Screw in Breaker | scosta | Electrical Inspections | 18 | 11/11/06 3:35 PM |
| Main service disonnect question | jmichalski | Electrical Inspections | 5 | 1/29/06 4:32 PM |
