Is there a difference in method to secure NM cable depending on the type of outlet box is used? I thought there was a 12 inch rule but then I heard that if a non-conducting box is used that changes to 8 inches.
Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In Last edited by gliebig; 3/25/11 at 1:14 PM.. Reason: Add Picture |
| Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I haven't heard that one Greg. I also follow the 12" rule.
I would be more concerned with the non-protected, incadescent lightbulb in a storage "closet". Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Hi Jeff, The "Closet" is actually an attic space with storage. I thought about that. There is no rule on protection of lights in attic spaces, but there is in "closets". This was in a knee wall storage area in a cape cod home. Had to crawl in for access. That's why I considered it as an attic.
Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In |
Hopefully someone has an answer to the 8"/12" question. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Is this the exception you are referring to; NEC 314.17(C) Exception: Where nonmetallic-sheathed cable or multiconductor Type UF cable is used with single gang boxes not larger than a nominal size 57 mm x 100 mm (2-1/4 in. x 4 in.) mounted in walls or ceilings, and where the cable is fastened within 200 mm (8 in.) of the box measured along the sheath and where the sheath extends through a cable knockout not less than 6 mm (1/4 in.), securing the cable to the box shall not be required. Multiple cable entries shall be permitted in a single cable knockout opening.
That must be it. So the way I interpret this applies to the way the cable is secured in the box which is something that we will not "see".
I am familiar with non-metallic boxes and most usually have a built-in "spring-type" clamping method that would prevent the cable from pulling loose anyway. So securing the cable(s) within 12 inches of the box is OK. I have also seen non-metallic boxes that have a knock-out without any internal clamping method. In those cases, the cable needs to be secured within 8 inches of that style of non-metallic box. I've attached some examples for help. Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In Last edited by gliebig; 3/25/11 at 1:12 PM.. |
Good post Greg.
Either way guys, the NM is not secured as required and the light will scorch teh OSB and may start a fire if left on too long IMHO.
Report it and move on. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
I'm with Greg on the light. No code prohibits it and it's not a fire hazard. I'm an extremely thorough inspector, but when something's in question I often defer to the axiom "don't be a pinhead".
| Short circuit failures with 12/3 NM-B cable and NM clamp connectors | pabernathy | Electrical Inspections | 10 | 4/17/11 1:43 PM |
| Commercial Electrical Inspections | jtedesco1 | Commercial Inspections | 29 | 1/12/08 5:03 AM |
| Did you KNOW this about NM Cable? | pabernathy | Electrical Inspections | 0 | 12/19/06 8:46 AM |
