"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com Last edited by nbhi; 7/8/08 at 9:43 AM.. |
Service cables shall be supported by straps or other approved means within 300 mm (12 in.) of every service head, gooseneck, or connection to a raceway or enclosure and at intervals not exceeding 750 mm (30 in.).
How about some conduit?
Foxe Smothers ( Owner / Inspector ) Pelican State Inspection Your Best Choice for Home Inspection in the Shreveport & Bossier City Area! www.PelicanState.Net www.ShreveportHomeInspector.net www.BossierCityHomeInspector.net foxe@pelicanstate.net LSBHI #10399 |
230.50 Protection of Open Conductors and Cables Against Damage — Above Ground. Service-entrance conductors installed above ground shall be protected against physical damage as specified in 230.50(A) or (B). (A) Service Cables. Service cables, where subject to physical damage, shall be protected by any of the following: (1) Rigid metal conduit (2) Intermediate metal conduit (3) Schedule 80 rigid nonmetallic conduit (4) Electrical metallic tubing (5) Other approved means |
Joe
SEC for residential should be protected? I have not seen this in this area. Is that only in certain areas of the country? Gary "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I live in the St. Louis, MO area; Illinois side.
Most of the homes I see on the Illinois side with overhead service are set up with: (1) Rigid metal conduit (2) Intermediate metal conduit You cross the river into Missouri, and some towns don't require conduit at all for SEC's. |
This usually means when the Type SE is loaated in a driveway, or near an area where it can be subjected to physical damage. |
| securing the mast? | bthompson1 | Electrical Inspections | 6 | 4/26/07 9:01 PM |
