| Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera. |
see anything wrong here
Jon,
Can you upload some larger photos? They are just a bit too small. ************************************** Shawn Rowe, CMI HomeFirst Inspection Services, LLC - InfraRed Specialist (Level 1 & Building Science certified) - Code Certified Residential Building Inspector - Certified Master Inspector -- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties -- |
how are these
Hi to all,
Jon, talk it through, what do you think may be wrong here? Regards Gerry Virtue is more to be feared than vice, because its excesses are not subject to the regulation of conscience. Adam Smith (1723-1790) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106
panel not bonded,main service cable loose and resting on pipes,3 different brands of breakers
Hi Jon,
Some details are a little hard to see from he pictures, but here are my thoughts.
What year is this house?
Is that a Siemens panel? ************************************** Shawn Rowe, CMI HomeFirst Inspection Services, LLC - InfraRed Specialist (Level 1 & Building Science certified) - Code Certified Residential Building Inspector - Certified Master Inspector -- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties -- |
Square D Arc Fault Check recall (on breaker-blue button) Catalogue #Q0115AFI… Date code CN-DN .
Those aren't the recalled breakers Jae.
I don't think that panel is the service equipment. The SEC assembly may be poorly supported, but from those pictures, I don't see much else. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ℠ Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
This is a recalled breaker. . .
Look at the test button....Square D is much smaller...easy to see even on the small photos
Just in case anyone needs a copy of my original recall post on the AFCI's...here is a link to it....
http://www.nachi.org/forum/showpost....84&postcount=1 AS for the wires on the copper pipe.....poor angle kinda like the crocidile hunter and the baby thing....... The panel image.....just can't see the breakers good enough....but here is a list of crossmixing breakers... The following panels will only accept breakers from the same manufacturer: Cutler Hammer, Federal Pacific*,General Electric ( half size ) and Square D* * New challenger breakers are fitting into FPE's and Cutler Hammer actually makes a UL approved Sq D Replacement Now. The following circuit breakers may cross mix.....defer to the manufacturer American Switch, General Switch, Arrow hart, Murray ( crouse hinds ) Challenger ( sylvania ) , Seimens ( IRE, Gould ), General Electric ( full size only) and Westinghouse. *NOTICE- only when the load center says they accept them..... And...I do have to question......and jeff stated it also...is this a Main Panel or a "Sub" panel......based on the image of the grounded and grounding terminations on different bars...not a problem in a sub panel.....but in a main panel lets home they connect to each other in some fasion....great obervation Jeff....... P.S...Probably why the GREEN BONDING screw is sitting their.......I would have CHUCKED it....if it was truly a "SUB" panel ( Remote Distribution Panel ) Paul W. Abernathy,CMI,CEI,CEPE NEC® Consultant/Columnist www.twitter.com/ElectricalGuru - ICC & IAEI Certified Electrical Inspector - ICC & IAEI Certified Electrical Plans Examiner - Look for my article in the Nov/Dec 2009 IAEI Magazine - 2007 "Top Gun" Winner - Mike Holt Enterprises " visit www.TheElectricalGuru.com Today !" Last edited by pabernathy; 10/31/06 at 12:56 PM.. |
As for the 'what is wrong' fun, I have to dig for scraps since everyone else did a good job. OK, here is my one table crumb, the grounded conductor ("neutral") is on a double pole breaker, and not re-identified as an ungrounded conductor ("hot"). Tom |
Paul W. Abernathy,CMI,CEI,CEPE NEC® Consultant/Columnist www.twitter.com/ElectricalGuru - ICC & IAEI Certified Electrical Inspector - ICC & IAEI Certified Electrical Plans Examiner - Look for my article in the Nov/Dec 2009 IAEI Magazine - 2007 "Top Gun" Winner - Mike Holt Enterprises " visit www.TheElectricalGuru.com Today !" |
tom |
| Thanks Nick I just hate it when I'm wrong | cbottger | Misc. Discussion | 0 | 6/9/07 3:01 PM |
| Messy work, but is it wrong? | mtimpani | Electrical | 8 | 9/9/06 10:56 PM |
| What's Wrong Here? | jtedesco1 | HVAC | 20 | 6/29/06 7:50 PM |
