Hello All:
Can you spot the problem with this disconnect. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
| Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Knife Blades not going into Slots correctly I see double taps ... Roy
Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Sounds like Roy nailed it. Blades not fully engaged and there's definitely a problem with the neutral bar.
Come on Roy!!! What about those wrong colored wires!!
Stick with the important stuff! (good call...) "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
You mean that black ones on the neutral bar? |
No the white ones on the fuse lugs...
Yes but 60 + years ago that was not much of a concern . Maybe they where coloured and have faded .. Roy
Roy, I'm still not concerned "today" ! :-0
Actually, if you put on your glasses the white is grounded. They do not attach to a fuse as they look at first glance. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission Last edited by dandersen; 8/13/11 at 9:49 PM.. |
Fused neutrals...
"Fused neutrals... "; Nope, put on your specs!
Roy wins this one.
This diconnect was signed off by the AHJ. My client walked away from the deal. To many things wrong with the old electrical. I like the sticker they use though. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
The white conductor is not connected to the fuse, look again. When was it inspected? The fact that there is an inspection sticker may not mean much unless if was recently inspected. Anyone could have added those other conductors after it was inspected.
Thanks,...gettin' old is still better than the alternative. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Is that a service disconnect for an older fused panel?
And I dont pay any attention to approval stickers either. RM is right that it could have been modified later, and it's also possible that the AHJ just missed stuff ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
That neutral is not fused. It just disappears from view behind the fuse clip and loops around to the bar.
| Double on AC disconnect | jmccormick | Electrical Inspections | 8 | 7/9/10 6:56 AM |
| What's Wrong Here? | jtedesco1 | Electrical Inspections | 10 | 12/9/07 9:36 PM |
| I wrote it up as a safety issue, but it it wrong or just stupid | dbush | Electrical Inspections | 7 | 10/17/07 11:09 PM |
