Old 4/6/10, 2:22 PM
Default See anything wrong here?
Realtor tells me that the 'builder's electrician' says there is nothing at all wrong with this wiring found in the garage. Comments?
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/6/10, 4:08 PM
Jeffrey R. Pope's Avatar
Default Re: See anything wrong here?
Please explain the issue as you see it. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/6/10, 4:17 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Ditto. What are we looking at?
Old 4/6/10, 8:29 PM
Banned
See 4 possible electrical faults here:
(1) No box connecter for wiring entering the pump pressure switch
(2) Unsupported NMD wire
(3) NMD wire needs to be protected from physical damage (up here anyways, any NMD below the 5' mark from the floor is considered to be open to physical damage and must be protected
(4) What size and type is the wire serving the load side of the pressure switch and down into the coduit to the well or storage cistern?
Free Books And Articles For Electrical jtedesco1 Electrical Inspections 14 1/6/08 6:45 PM
Imagine There's A Heaven jmckenna1 Miscellaneous Discussion for Inspectors 3 12/23/07 11:15 PM
Grandpa, what is wrong with the patio? mcyr Exterior Inspections 1 5/12/07 10:29 PM
Whats wrong in this pic cbottger Inspecting HVAC Systems 11 3/11/07 6:16 PM
