Old 10/14/07, 2:34 PM
David C. Macy's Avatar
Default Service amperage
Round meter base.
100 amp main breaker.
Appears to be #2 or #4 SEC Aluminum.
How would you report the service amps for this home? 60 or 100A.
I say the meter base is 60A
The SEC is 70A
I would report this as a 60 amp service.
ID:	15171   service-amperage-106907-007-small-.jpg.jpg
ID:	15172   service-amperage-106907-025-small-.jpg.jpg
ID:	15173   service-amperage-106907-024-small-.jpg.jpg
Old 10/14/07, 3:05 PM
cbuell's Avatar
cbuell cbuell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Service amperage
First of all the SEC's are copper and most likely #4. I tend to call these: "upgraded 60 amp services ." Most likely, because it is #4 copper, the 100amp panel will be ok, but I advise my buyer they should anticipate upgrading the service.
Old 10/14/07, 3:22 PM
Are the SEC tin coated copper?
Old 10/14/07, 3:29 PM
cbuell's Avatar
Given the age of the wire they would would have to be (my mind keeps wanting to find an exception )
Old 10/14/07, 4:20 PM
Unmoderated Guest
If...
Then why......
The SEC is 70A
If you are not sure of the size how can you call it anything????
If it is #2AL or #4CU then it is indeed a 100A service.
THIS is a perfect way to report it.
Old 10/14/07, 6:10 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Would just like to add that Paul Abernathy has told us in the past that the meter base is just a guide rather than a limitation.
And the Gauge is a limitation as is the Main Breaker,taking smaller of the two as the limitation.
If the gauge is not rated for 100 amps or better I would call that a defect.
Speedy is right about needing accuracy.
Old 10/15/07, 1:19 AM
Without knowing more about this house I would never say 100a was too small. "Fossil" appliances could make 100a overkill.
Old 10/15/07, 1:51 AM
relliott's Avatar
Hi Greg..I should have clarified better as I was refering to the specific situation above ,as the Breaker is rated at 100 amps.
Though fossil appliances use more juice than newer more energy efficient models.
Old 10/15/07, 1:59 AM
Marc D. Shunk's Avatar
Banned
I think Greg meant fossil fuel burning major appliances, rather than those that run on electricity.
New Washington Legislation Submitted gdomagala Legislation, Licensing & Legal Issues for Inspectors 293 2/10/08 2:20 AM
Rating Service Amperage scosta Electrical Inspections 3 9/25/07 11:50 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 6:58 PM
Service Entrance Amperage? jfunderburk Electrical Inspections 18 6/16/06 11:16 PM
