Old 5/4/08, 8:00 PM
mnicholet's Avatar
mnicholet mnicholet is offline
Please Note: mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Service box ground
Here is a picture of a neutral service entrance and earth grounding conductor bond at the service box/panel. What are the two big screws for on the neutral bus connector? Is there a bonding screw in this picture? The grounding equipment conductors are all attached to the back of the service panel.
Old 5/4/08, 8:42 PM
Unmoderated Guest
Default Re: Service box ground
I am not at all familiar with those panels, but it does seem the bond screw is missing. Maybe it goes in that empty hole right above the larger copper wire terminatedon the neutral bar?
Old 5/5/08, 12:40 AM
Bruce Erny Bruce Erny is offline
Please Note: Bruce Erny is a non-member guest and is in no way affiliated with InterNACHI or its members.
The two large screws are holding the long neutral bar in place and attaching it to the neutral conductor just below them. The bonding screw should be just under the bar in the empty hole. If this is a sub panel, the screw should not be there. If it is a main breaker panel than somebody forgot to install the bonding screw (main bonding jumper)
Old 5/5/08, 12:43 AM
Jeffrey R. Pope's Avatar
That's because they manufacture FPE in the USA anymore. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 5/5/08, 1:42 AM
mnicholet's Avatar
Thanks for the information. This is a main service box/panel combo. With no bonding screw. Essentially, the grounding equipment conductors are an open circuit. Is the bonding screw typically located under the neutral bus connector bar?
Old 5/5/08, 6:40 AM
Unmoderated Guest
Yeah, I knew it was FPE (Canada). I just never saw one with the ground screws right in the back of the box like that. Interesting setup.
Old 5/5/08, 9:04 AM
usually a screw thru the bar to the can or a strap from the bar to the can. If main panel it must be there.
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Service panel bonding to ground abolt Electrical Inspections 22 12/18/07 2:47 PM
Looking for comments on this service ground wire connection cbuell Electrical Inspections 6 2/8/07 6:27 PM
