Old 11/27/06, 12:38 AM
Default Service Capacity
The service conductors were #2 copper, the main panel and main breaker were rated at 100 amps, and the meter was rated at 200 amps. I don't see very many of the smaller round meter bases, so I thought I would get some confirmation from the pros on this BB. I believe that is a 60 amp rated meter base, which makes the service capacity 60 amps. Upgrading the meter base would make the service capacity 100 amps. Is that right?
Old 11/27/06, 1:07 AM
jschulte jschulte is offline
Please Note: jschulte is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Service Capacity
Be careful. According to one of our local (very knowledgable) electricians, there were quite a few 100 AMP round meter bases produced. There are no obvious markings on the exterior of the base, though.
If the panel is 100 AMPs, I state that it is likely 100 AMPs, but there is a possibility that it is only 60 AMPs, they need an electrician to determine which if it is a concern.
Old 11/27/06, 3:31 AM
Darrell B. Hadler's Avatar
Darrell B. Hadler Darrell B. Hadler is offline
I'd call that a 100 amp service...BUT I never even dreamt of checking the actual meter BASE? I know they are old and watch for wire protection and height requirements as we usually see upgrades are necessary or will be on their next reno project involving electrical work.
Learn something new every day...WOW
Darrell Hadler CMI
Five Star Home Inspections
Medicine Hat, AB. Canada
NACHI# 04111082 Cell phone# (403)502-3593
Inspected once . . . inspected right!
Old 11/27/06, 2:59 PM
Paul W. Abernathy's Avatar
Paul,
Many times they increase the size of the conductors but that ends up being where they stop. You have to understand while the conductors have a capacity of 200A the limiting factor on the system is the lowest rated in the setup.
In this case if the OCPD is 100A and the Panel's rating is 100A......do not rely on the round meter can...back in the DAY they even approved round models for 100A .....so better to use the factors you know and that would be the Service Enclosure and OCPD....as the size.....
Paul W. Abernathy,CMI,CPI,CME
Old 11/27/06, 5:32 PM
My house in Md also had a 200a service using the small square meter can. You really can't prove much by what a PoCo will allow.
Old 11/27/06, 5:37 PM
No doubt Greg...While in some cases it can be a piece to the puzzle....the use of the meter can should never be the determining factor. With experience it can aid in your process but in older homes it just can aid in getting the HI confused.
Old 11/28/06, 7:47 PM
Great info. Thanks Paul and Greg.
Old 11/28/06, 10:52 PM
The real issue with meter bases is not volume, it is wire bending space. They make the bigger ones so you can enter at the bottom and have enough room to loop into the top lugs of the meter base. If it is 4/0 or less and you go straight into (45 degree bend or less) "lay in" lugs you only need 4".
New Washington Legislation Submitted gdomagala Legislation, Licensing & Legal Issues for Inspectors 293 2/10/08 2:20 AM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 6:58 PM
Help Determining Reportable Service Size cbarrows Electrical Inspections 8 7/19/06 8:12 PM
Electrical Inspection with Temp. Service? dandersen Electrical Inspections 16 6/27/06 11:41 PM
