ED HULL is a non-member guest and is in no way affiliated with InterNACHI or its members.
Need to know, having a 3-200 amp service with a ct metering on transformer pole, meter socket is being supplied by Bluebonnet elec. Would I use 2/0 from the riser to the galvanized trough, with line taps going to 3 seperate 200 amp disconnect panels. Can i instead use 3 seperate 200 amp breaker box with 2-100 amp breaker in each box? Each panel will split 100 amp to a seperate 100 amp panel. All this is going to 6 rental cabins using 100 amp breaker boxes.
Are you an electrician?
| Service Disconnect | Steve Brewster | Electrical Inspections | 4 | 9/29/08 11:26 PM |
| Exterior Service Disconnect Clearances? | rcramer | Electrical Inspections | 18 | 7/28/07 1:12 PM |
| Service disconnect | jharashinski | Inspecting HVAC Systems | 25 | 4/7/06 10:34 PM |
