Hard to see from the pictures, but the right side of the breaker on the bottom side appears to be burned. The left side is not.
Is this a concern? And what might have caused it? |
Good catch Will, probably a loose connection.
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
I think what you're looking at there is the "arc chute" of that older style Cutler Hammer main breaker. It aparently either took a lightning hit once, or cleared a hard bolted type fault one or several times. As an electrician, if I saw that, I'd highly advise replacement of the breaker.
Agreed with Shunk.......not worth second guessing it to the consumer. Defer and have it viewed by a licensed electrician.
as Shunk stated...it could be from a lightning surge, line surge or fault as well but better to be safe than sorry so I would want to look at it more closely personally so defering it to a like minded electrical contractor will serve the clients safety much better. Paul W. Abernathy |
| Exterior Service Disconnect Clearances? | rcramer | Electrical Inspections | 18 | 7/28/07 1:12 PM |
| Quick question on Service size | rslocum | Electrical Inspections | 2 | 6/10/07 1:10 AM |
| A/C Disconnect question | rslocum | Inspecting HVAC Systems | 15 | 9/21/06 12:16 AM |
| Disconnect and Main panel | srowe | Electrical Inspections | 10 | 6/13/06 7:49 PM |
| Service disconnect | jharashinski | Inspecting HVAC Systems | 25 | 4/7/06 10:34 PM |
