Is there a requirement for clearance over stairs and doorway landing? (I know about the 10ft requirement for balcony/decks and yards, but I can not find any for stairs and doorway landing.
Peter |
| Find an InterNACHI certified New Jersey Home Inspector (and anywhere else in North America) |
Someone can reach up and grab it which makes it a safety hazard. A walkway/balcony needs 10' clearance...my thoughts.
That's my opinion too.
Peter |
(B) Vertical Clearance. The vertical clearance of final spans above, or within 900 mm (3 ft) measured horizontally of, platforms, projections, or surfaces from which they might be reached shall be maintained in accordance with 230.24(B). 230.9 Clearances on Buildings. Service conductors and final spans shall comply with 230.9(A), (B), and (C). (A) Clearances. Service conductors installed as open conductors or multiconductor cable without an overall outer jacket shall have a clearance of not less than 900 mm (3 ft) from windows that are designed to be opened, doors, porches, balconies, ladders, stairs, fire escapes, or similar locations. Exception: Conductors run above the top level of a window
shall be permitted to be less than the 900-mm (3-ft) requirement. Paul W. Abernathy |
Thanks Paul, just what I needed.
Peter |
Although Paul answered it very eloquently, here is an attached PDF file to keep handy.
Regards, |
| Florida Licensing Bill - Action Soon | jburkeson1 | Legislation, Licensing & Legal Issues for Inspectors | 250 | 7/1/10 4:50 PM |
| Service ground requirements? | kcabral | Electrical Inspections | 2 | 1/22/09 8:14 PM |
| Larger wires at service drop | mtimpani | Electrical Inspections | 33 | 1/19/09 8:35 AM |
| Service Drop Q | alarsen1 | Electrical Inspections | 11 | 2/25/07 9:45 AM |
| Service Drop and SEC | jpope | Electrical Inspections | 11 | 1/14/06 11:15 PM |
